Author: Subject: type 9 reverse light switch?
ned
posted on 2/7/04 at 11:44 AM Reply With Quote
Is this the bit on the right side of the gearbox just below the gear lever? There are 2 little contacts that look like they should have a plug or somesuch on them.
As I'm not going to run a reverse light I want to take this bit off as it falls right where the 2 vertical tubes are in my chassis where the tranny tunnel narrows with my engine mounted. Looks like part of it unscrews with a largish spanner. would i ned to put something in place to blank it off?
Anyone confirm/see any probs in doing this?
cheers,
Ned.
[Edited on 2/7/04 by ned]
beware, I've got yellow skin
DaveFJ
posted on 2/7/04 at 12:01 PM Reply With Quote
yep sounds right to me
Dave
posted on 2/7/04 at 12:38 PM Reply With Quote
The switch only goes into the bit where the gearstick fits - no oil there, so no leaks! You might like to put some sort of bung in the hole, if only to stop the dirt getting in (but it's not a big issue, really)
ned
posted on 2/7/04 at 12:47 PM Reply With Quote
Thanks, this is good news. There was very minimal clearance as it is, that'll be coming off tomorrow then!
cheers,
Ned.
