mikemph
| posted on 7/2/11 at 09:16 PM |
Sierra MK vs Bailey Morris prop weight
Does anyone know if there is a noticeable weight difference between a sierra prop that has been modified by mk for bec to the weight of a Bailey
Morris trt prop
| posted on 7/2/11 at 09:27 PM |
Yes, there is a noticable weight difference. Not sure exactly what the difference is but the TRT part of the prop is effectively a tube within a tube
bonded with rubber.
Phil
watsonpj
| posted on 7/2/11 at 09:38 PM |
I don't know the weight difference but as said its significant as its 2 bits of tube and some rubber but having had a solid prop and changing to
a TRT I wouldn't change back its a nicer ride with a TRT and probably better for the mechanicals.
needforspeed
| posted on 7/2/11 at 11:34 PM |
how much do they come in at? any pics?
mikemph
| posted on 9/2/11 at 05:00 PM |
Which section should have the slider?
Which section should have the TRT?
