tony-devon
| posted on 23/2/11 at 11:00 PM |
what is the size/thread of the brake hoses
Hi, I have tried the search function, but not much joy, maybe using wrong or too many keywords?
Im currently working out the shopping list to make up the brakelines for the back of my build, but need to know what the size and thread is of the
brake line into the rear calipers
Im planning on running brainded hoses, but want to use banjo bolts ideally, if not then there are some adaptors, but as I havent a clue what thread it
is, I cant even get started.
2 lines from my master, 1 back to each caliper is cheaper, but think I will got with some form of T piece in the system, neater that way, actually
thinking about it,I think I will go with 1 line back to one caliper, double banjo, with a line over to the other caliper
anyone see a problem with this? its how we do the front brakes on bikes?
[Edited on 23/2/11 by tony-devon]
heavy is good, heavy is reliable, and if it breaks, hit them with it
blakep82
| posted on 23/2/11 at 11:15 PM |
i can see plenty of problems, namely you've not listed a single detail about what master cylinder, or calipers you're using
running braided hoses throughout is not a problems at all, its how i did it
________________________
tony-devon
| posted on 23/2/11 at 11:21 PM |
DOH
well the master cylinder thread is easy, its a honda bike one and its 5/8th piston.
the calipers are from a sierra, solid discs
was so busy trying to compile an order before going back to the garage that I forgot about details
I use venhill lines as they are well priced and come sleeved in all pretty colours
just measuring and working out the routes, but a lot will depend on if I use the straight fitment, like the standard flexi hose, or if I go with 90
degree banjos to route the hose etc
blakep82
| posted on 23/2/11 at 11:27 PM |
sierra calipers are M10x1 thread, and i think you can use banjos, but i used 90 degree swivel fittings, its like a male threaded, the threaded part
spins round on the tube, which is flared, like a normal pipe. i *think* bajo's work, but my claipers had been painted be the last owner, and the
finish wasn't very smooth, so wouldn't have sealed very well.
i'd go for 1 line front to back, T peice (which you can either get in metri or imperial) in metric M10x1, and 2 seperate pipes to the calipers.
2 banjos on the MC and sperate pipes to each caliper is how i did the front of my car, but the way you're talking of doing the back, i wonder if
you'd have problems bleeding them?
have you checked russ bosts prices? he does them too! very nice
matt_gsxr
| posted on 24/2/11 at 10:08 AM |
Tony,
That is what I have. Seems to work.
The Sierra calliper is not designed for a banjo but it can work. You may need to file the area around the bolt to get it nice and flat so as to seal
properly. I had to trim down the banjo bolts too, but neither is a big deal.
You could use a 4-way T-piece (if you know what I mean) and include a pressure switch for the brake lights. I didn't, but it is an option that
simplifies the wiring.
Matt
