mads
| posted on 26/2/11 at 11:12 PM |
master cylinder choice for wilwoods (i know been asked before)
so I'm building an Indy R and got wilwood disk brakes all round to fit. what master cylinder do i need to fit (and will allow me to be IVA
compliant)? i've seen that the bore sizes for fronts tend to be 0.625 and 0.75 for rear.
the footwell end panel has only a single hole behind the brake pedal so does that mean I can only use a dual master cylinder or can I use two separate
reservoirs without having to make the hole bigger? or is there a master cylinder with dual bore outputs of different sizes i.e. 0.625 for front and
0.7/0.75 for back?
and do i need a low brake fluid indicator on the dash for IVA? if so, what size m/c choices do i have?
cheers,
mads
[Edited on 27/2/11 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
RazMan
| posted on 27/2/11 at 09:52 AM |
I think your rear m/c needs to be a bit smaller if you have got 4 pot Wilwoods all round - 0.75" would be too large IMO. I used 0.60"
Front and 0.60" Rear to get the right balance in my middy. A front engined car might benefit from a 0.65" Rear but a lot depends on the
size of the discs you are using.
Raz
mads
| posted on 27/2/11 at 03:17 PM |
cheers Raz. I have got 255mm and 270mm discs (though currently awaiting help as in which ones go where).
RazMan
| posted on 27/2/11 at 04:29 PM |
Assuming you have the larger discs on the front, I would say that 0.60" Front and 0.65" Rear would be a good starting point. The
0.75" m/c would be more suited to the clutch IMO. Brakes are such a difficult subject and everyone will have their own way of setting things up.
I could go into a lot more detail and ask about your caliper piston sizes, pedal ratio etc etc but if you have a bias bar then things are a little
more adjustable and you can compensate a little either way.
*edit*
I have just reread your opening post and it looks like you might need a dual m/c (as fitted to a number of production cars). If you can make the
necessary mods to the chassis, I would go for 2 x single m/c as you can play with the sizes a lot easier.
[Edited on 27-2-11 by RazMan]
Raz
