Author: Subject: question about disc sizes on front and back
mads
posted on 27/2/11 at 03:11 PM Reply With Quote
hey up all,
loads of questions from me this weekend (sorry!)...
Got the discs from RD when I participated in the Wilwood brake kit group buy.. I cant remember which one they said goes where though and they are closed today.
The two sizes are 255mm and 270mm. The 255mm is a deeper disc so thinking these should go on the rear, particularly as they are smaller. However, the 270mm ones have less contact space for the pads, so should they be going on the back?
mads
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
tomgregory2000
posted on 27/2/11 at 03:17 PM Reply With Quote
bigger on the front
mads
posted on 27/2/11 at 03:27 PM Reply With Quote
here are some pics in case they help...
255mm disc
255mm disc
255mm disc
270mm disc
270mm disc
270mm disc
mookaloid
posted on 27/2/11 at 04:37 PM Reply With Quote
Think of it as leverage - the bigger disc has better leverage and goes on the front.
pekwah1
posted on 27/2/11 at 04:45 PM Reply With Quote
i know as a rule of thumb you want more braking on the front, but is this always the case?
I have found that on all of the RWD cars i've owned, they've always had bigger discs on the rear than the front, not by much but slightly bigger.
I gues this is down to the drive being through those wheels and needing the extra force?
phelpsa
posted on 27/2/11 at 05:18 PM Reply With Quote
Often to do with the handbrake. You need a nice big disc to get enough leverage for the handbrake to hold the car on a lot of modern cars, or the centre of the disc is a drum for the handbrake (like subarus) requiring a large disc.
adithorp
posted on 27/2/11 at 05:27 PM Reply With Quote
They've probably equiped with a load valve so do work the rear brakes hard when fully laden.
In this case the big ones go on the front. If they're Sierra convertions from drums then you'll have to have the rear hub flanges reduced in diameter for them to fit.
http://jpsc.org.uk/forum/
MakeEverything
posted on 27/2/11 at 05:43 PM Reply With Quote
Although the larger discs have a smaller surface area per pad, it has a greater radius. You should be able to work out the area of each discs surface contact, but the larger discs should go on the front IMO. Even if they do have a thinner contact surface, the extra diameter will help prevent fade under heavy braking.
Kindest Regards,
Richard.
mads
posted on 28/2/11 at 07:13 AM Reply With Quote
cheers folks. looks like on the front they go!
hughpinder
posted on 28/2/11 at 09:44 AM Reply With Quote
Be careful - the braking force is proportional to:
The area of the piston(s) in your caliper, and the disk radius of the disk to the centre of the pad.
Its inversely proportional to the diameter of the master cylinder.
The reason the bigger disk is sometimes on the back is to make the handbrake work more easily. You will find the rear caliper piston diameter is smaller so that the foot brake does not overbrake the rear.
You should be able to offer those disks up to the hubs and hold up the calipers - they'll only fit with one set of calipers, as they are quite different in diameter and offset.
Regards
Hugh
(to give a reasonable assessment we would need the above info, plus the weight balance of your car.)
