Author: Subject: Has anyone used Nissan 350z Differential & Spindles?
beagley
posted on 7/3/11 at 04:05 PM Reply With Quote
Planning out the desired parts I'm going to need and hit a stumbling block with the rear end. My engine is going to be a 2.0L duratec (similar to Flak Monkey's) running around 220-230 bhp.
Doing some reading on the MX5 differential (which was my original donor parts) I came across alot of posts saying that the stock diff wouldn't handle that much power for long. Was thinking of using the differential and rear end components from the 350z instead. Stock power for that car is 287 - 305 so my engine wouldn't risk blowing it up and its an independent rear suspension as well.
Anyone tried to use these parts before or am I breaking new ground?
Beags
I'm not scared!!! I'm just marking my territory.
MikeFellows
posted on 7/3/11 at 04:13 PM Reply With Quote
what do the guys that use 22b engines in MX-5's use?
a 22b is easily tuned to 400bhp+
maybe they use the rx-7 diffs?
rodgling
posted on 7/3/11 at 04:19 PM Reply With Quote
E36 diff and driveshafts will be good for over 300 bhp. The diff's a bit on the heavy side though.
hicost
posted on 7/3/11 at 06:04 PM Reply With Quote
Love it!
I love it when people say easily tuned to 400+
After 10 years in that area which part is easy?
James
"I cant do that without accidentally grabbing hold of the work of the divine potter"
Marcus
posted on 7/3/11 at 06:38 PM Reply With Quote
400bhp dead simple if you throw money at it and give it to a specialist!!
Marcus
Because kits are for girls!!
