phil clegg
| posted on 7/3/11 at 08:35 PM |
plate diff qwery
i fitted a 3.6 7" lsd from a gp midget racecar, its almost no slip and is like driving a welded diff ,i stripped it down and it is full of
plates like a bike clutch,would i be ok to remove some to limit the locking or would i be better with a standard one? i cant fit my spare diffs
because the lobros dont fit thanks... also i need a 3.1 diff if anyone can help
[Edited on 7/3/11 by phil clegg]
snapper
| posted on 7/3/11 at 08:47 PM |
You probably have a diff set up with very big ramp angles, you can't just remove plates.
It will need setting up for your particular use.
I eat to survive
I drink to forget
