Hammy360
| posted on 12/3/11 at 07:15 PM |
Rear sierra brakes
Ive bought new discs and pads for my 7 kit, the discs are 10mm think and trying to fit pads into the calipers I can only get about 6-7mm gap between
the pads where the disc should fit in. Ive tried pushing the caliper piston back on both calipers and theres no way! (and yes Ive tried a lot of force
to get them back) Anybody else experienced this? Are my calipers seized, Ive had a completely wasted day in the garage today!
austin man
| posted on 12/3/11 at 07:23 PM |
are the sliders seized
jimmyd
I don't know about Sierra rear calipers but on most other rear calipers you need to screw the pistons back, you'll not push them.
J
adithorp
| posted on 12/3/11 at 07:27 PM |
The rear (handbrake caliper) require the piston to be turned at the same time as pressing, to retract the piston and reset the handbrake mechanism.
G-clamp and grips or angle grinder spanner will do it, with a bit of perserverance or there's a special tool. Once the pistons are back
DON'T operate the handbrake lever untill you've pumped the pistons out with the foot brake.
http://jpsc.org.uk/forum/
| posted on 12/3/11 at 07:56 PM |
Screw and push do not use force. handbrake actuatorlever must be fully released and returned against stop.
if you get a very cheap " brake cube" tool that fits on a 1/2" socket it makes things a lot easier.
