KECHICHE
| posted on 15/3/11 at 08:23 PM |
dohc engine help pls
hi guys can you pls help with this building a locost got the sapphire dohc injection unit to high for the bonnet could you pls edvice on what kind of
carb i can use to gain some room to fit the bonnet, cheers Alex
norfolkluego
| posted on 15/3/11 at 08:31 PM |
So is it the fuel rail thats too high for the bonnet?
KECHICHE
| posted on 15/3/11 at 08:45 PM |
ill try to explane this propely the injection unit fitted to the engine in a angle that raising above the engine block,hope that helps,cheers
norfolkluego
| posted on 15/3/11 at 08:52 PM |
Picture would help
KECHICHE
| posted on 15/3/11 at 09:03 PM |
Hi sorry i could not load the photo but i managed to email it to you if thats ok ? sorry
SPYDER
| posted on 15/3/11 at 09:05 PM |
Is it the engine pictured below? If so I would do a "cut and shut" operation to lower the plenum. I've seen it done on an injected
Pinto engine. The DOHC can't be much different.
Bike carbs might be an alternative I suppose. You might contact Bogg Bros and enquire.
KECHICHE
| posted on 15/3/11 at 09:07 PM |
yed thats the one,cheers nice one.
norfolkluego
| posted on 15/3/11 at 09:16 PM |
Understand now.
As said bike carbs are one way to go, the other being Weber or Dellorto.
Bike carbs are a fair bit cheaper to buy but you'll need a manifold to go with them, around £300 from Bogg Brothers (that's what I
paid).
If you bide your time on eBay you could maybe pick up a pair of second hand Dellorto 40s and a manifold for £250, I did when I had the Crossflow
[Edited on 15/3/11 by norfolkluego]
KECHICHE
| posted on 15/3/11 at 09:22 PM |
thanks for your time ill shop arround.
SPYDER
| posted on 15/3/11 at 09:45 PM |
Does anyone make a Weber manifold for the DOHC engine?
austin man
| posted on 15/3/11 at 09:49 PM |
If I was at the engine install stage I would seriously consider a diffrent engine as the DOHC engine is a heavy unit and no much in the way of tuning
a 2 litre pinto would give a bigger power output
norfolkluego
| posted on 16/3/11 at 12:17 AM |
And a Zetec can be picked up for as low as £50 although you still have to spend the money on the carbs etc. you do get a better engine
KECHICHE
| posted on 16/3/11 at 04:51 PM |
if i get the zetec engine will the t75 gear box bolt straight on? thanks
big_wasa
| posted on 16/3/11 at 05:55 PM |
Yep.
There is nothing wrong with the twink IF you you can make all the bits to install it your self. If you want of the shelf parts get a zetec you wont be
disapointed.
KECHICHE
| posted on 17/3/11 at 03:10 PM |
cheers,that a nice looking set up there.
r1_pete
| posted on 17/3/11 at 03:54 PM |
There is a carb variant of the twin cam, uses an odd ford/weber carb, I had one and was going to use it in an MGB, but to be honest, including buying
a zetec it was cheaper than doing anything useful with the twin cam.
Less than £200 will buy you a Zetec bike carb manifold from boggs, and as there is no coolant to worry about in the manifold making your own is dead
easy, just don't weld the runners on the wrong side of the manifold flange like I did......
[Edited on 17/3/11 by r1_pete]
KECHICHE
| posted on 18/3/11 at 08:52 PM |
thanks for the edvice to be honist i not concidered anything yet just finding out the easy and qwicker option,it`s getting to much now on what to
do,cheers Alex
