Author: Subject: Trailing arm diameter?
posted on 26/3/11 at 02:35 PM Reply With Quote
I'm making two trailing arms from Land Rover rear bottom arms, cutting off the threaded bit that goes through the bush and putting M20 rose joints there instead. This is to replace the top A frame for something a bit more articulate.
The arms are 27mm diameter and with a 19mm hole for the rose joint thread are they thick enough?
