Author: Subject: Suspension Travel in Bump
liam.mccaffrey
posted on 26/3/11 at 09:00 PM Reply With Quote
What sort of suspension travel are you folks seeing in bump?
Build Blog
Build Photo Album
MikeCapon
posted on 28/3/11 at 09:24 AM Reply With Quote
Hi Liam,
As no-one else has replied here's my contribution.
The bump movement is reliant on the total travel available. For a seven type car the total travel will be around 100mm and bump will be 60-70% of that, leaving 30-40% as droop.
HTH
Mike
Frosty
posted on 28/3/11 at 02:24 PM Reply With Quote
I think most 7 setups are aimed at around 3 inches of total damper movement, allowing 2 inches of bump, and 1 inch of rebound.
Put another way, the weight of the car compresses the suspension around an inch, giving a further 2 inches of movement.
Windscreen Wipers
Need windscreen wipers for your car? Order from a friendly kit car owner.
Don't pay a garage to do them. You built a car for God's sake - I'm sure you can fit your own wipers!
