Author: Subject: New Springs
phoenix70
posted on 5/4/11 at 02:32 PM Reply With Quote
New Springs
Hi Guys,
I'm converting my MK from pinto power to BEC and I believe I need to change the front springs for something a bit softer. Currently the springs on the car are the standard one provided by MK, so I've no idea what they are, any suggestion on what I need to change them to?
Scott
Daddylonglegs
posted on 5/4/11 at 02:36 PM Reply With Quote
Those ones you get in a Parker pen should do the job I reckon
OK, I'll get my coat
[Edited on 5/4/11 by Daddylonglegs]
Mr Whippy
posted on 5/4/11 at 02:41 PM Reply With Quote
mk should be able to tell you as they have built bec cars themselves
Daddylonglegs
posted on 5/4/11 at 03:08 PM Reply With Quote
IIRC I've got 350lbs front and 200lbs rear if that helps. I'm running a 2l Pinto on a McSolrey +442 Locost. So I'm guessing it'll be quite a lot less on the front.
John
bigrich
posted on 5/4/11 at 04:31 PM Reply With Quote
i think you will need somewhere around 275 front and either your original rears or 175.
I would change the fronts and see how it feels.
