Bigboystoys
| posted on 14/4/11 at 07:09 AM |
Trailing arm brackets
Can anybody help. Trying to het hold of the brackets I need to weld to my capri atlas axle to allow for the trailing arms
thanks
tul214
| posted on 14/4/11 at 07:16 AM |
Fostek?
1.6 Raw Super6 sold
omega 24 v6
| posted on 14/4/11 at 07:56 AM |
You can make your own as per the book Using IIRC 100X50 box section drill ( hole saw) a hole through the wide face the dia of your axle and then cut
it in half down the erw seam.
big_wasa
| posted on 14/4/11 at 08:15 AM |
I used Locost/Kit Car Escort MKIIAxle Brackets|eBayUK for both mine.
[Edited on 14/4/11 by big_wasa]
myke pocock
| posted on 14/4/11 at 10:18 AM |
Just remember, when I welded mine on to the axle I was told to run the welds right round the axle to prevent possible heat distortion if you only weld
the actual bracket area of contact.
