karlak
posted on 19/4/11 at 01:09 PM |
Are these GSXR TB's correct?
Are these the correct GXSR 750 throttle bodies to be able to split ?
![](/galpreviews/) ![](/gallery/)
and the other side
[Edited on 19/4/11 by karlak]
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
scutter
posted on 19/4/11 at 01:17 PM |
They look ok fella, just the extended fuel rail to sort.
ATB Dan.
Strontium Dog
posted on 19/4/11 at 01:18 PM |
Yes Mate, looks like it, but you'll need a custom fuel rail if your gonna use the Suzi injectors! You will need some other bits making up on a
lathe as well and some welding to extend the linkages![](/images//smilies/wink.gif)
karlak
posted on 19/4/11 at 01:22 PM |
Oh flippin 'eck.. Will it never end
We have new neighbours due to move in next door, I really really hope the guy has a lathe and welder to put in the workshop
So how much would I expect to be paying for these throttle bodies then ?
g60_edge
posted on 19/4/11 at 01:32 PM |
They are what I'm using.
I used the zetec injectors and fuel rail. For linking the mechanims I used small pieces of steel and a couple of m4 screws.
The only custom bit was making a bracket to fix the fuel rail to the injectors. This was just bits bits of steel welded together, nothing
complicated.
I did turn some new pieces to get the spacing right as well.
Think I paid around £70 for mine
[Edited on 19/4/11 by g60_edge]
karlak
posted on 19/4/11 at 01:47 PM |
Ahh, I see.
So the fact I am using a Duratec, they will be spaced for a duratec inlet manifold. Therefore would the duratec fuel rail be the correct spacing
straight off ? I guess I use the injectors into the TB's and not the original Duratec position (blank them off?).
Dont worry, I do have a mechanic to help me do all this. But, would just like to look as if I have got a bit of a clue about these thngs
Any detailed pictures of a gsxr TB setup on the engine would be handy.
big-vee-twin
posted on 19/4/11 at 01:58 PM |
Blank off the suzuki injector ports using roofing bolts and engineering glue and use the duratec fuel rail and injectors, the ITB's can be very
easily respaced using bits and bobs from B&Q dont panic.
You will need some 5mm screwed rod, some 12mm ally tube and some 20mm wide ally strip all from B&Q
![](/galpreviews/gsxrduratec .jpg) ![GSXR on Duratec](/gallery/gsxrduratec .jpg) GSXR on Duratec
Have a look in my photo's you will see how they split, and how they are spaced using the tube and the extended linkages
[Edited on 19/4/11 by big-vee-twin]
http://www.triangleltd.com
fatbaldbloke
posted on 19/4/11 at 08:51 PM |
Or you can make up a fuel rail to suit the original Suzuki injectors:
![](http://www.fatbaldbloke.co.uk/westfield_articles/article_gallery/tbs complete large D.jpg)
matt_gsxr
posted on 24/4/11 at 09:05 PM |
Some gsxr TBI's (gsxr600) use 5mm threaded rod, some (gsxr1000) use 6mm rod.
Not sure what gsxr750 use.
Extending the linkages isn't too tricky, I bolted with M4 and a bit of JB weld for good measure.
Flak Monkey can make you a fuel rail at a very good price, but you probably don't need to both with the suzuki injectors.
You might need a gsxr750 airbox to get the inlet rubbers, but these are about £20 on ebay (make sure you get the right ones though).
Matt
