mads
posted on 25/4/11 at 08:28 PM |
struggling to figure out how my wilwoods attach
I must be having a moment because I cant figure out how my front wilwood calipers are supposed to attach to my (sierra) upright.
Can someone confirm which way they are meant to go and where the spacers are meant to be?
This is first way I tried is:
wilwoods 1
(Notice the spacers location)... by doing it this way the disc seems to sit too far out and also rubs on the caliper. Disc is 270mm.
I then try with the spacers at different location:
wilwood 2
But now the disc sits further in to the car and again not central in the caliper.
What am I doing wrong? Plus I seem to have a number of 'spare' bolts and nuts left over. Are the socket-head bolts going into the mounting
bracket from the caliper supposed to be secured by a nut on the other side? the bolts i have supplied finish just inside the bracket itself.
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
snapper
posted on 26/4/11 at 01:38 AM |
The disc bells don't look deep enough on a Sierra hub.
Some Willwoods came with a simple Ally block which you drill to fit, my be you need a deeper block.
I eat to survive
I drink to forget
Pezza
posted on 26/4/11 at 05:15 AM |
Yeah the discs look wrong to me too.
Here's mine mounted, bolted straight up simply.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
Ben_Copeland
posted on 26/4/11 at 06:02 AM |
If they are powerlites then you disc is wrong. Have you got the wilwood disc or a sierra solid one? The wilwood disc is 257mm. Where did you get all
the bits from? I sell the powerlite kits sometimes on eBay. So give me a shout if you need any bits.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
gavin174
posted on 26/4/11 at 08:00 AM |
looks to me like you have put rear discs on the front
front discs have a much bigger offset than that
mads
posted on 26/4/11 at 12:27 PM |
cheers folks. decided to browse the RD website last night and realised what I'd done.
does anyone know if there is a difference in the wilwoods calipers for a rear drum and rear disc replacement? realised I've ordered the kit for
sierra rear disc but I need the rear drum kit. If the calipers are the same then I could get away with just buying more discs rather than a whole new
kit at £400+
Ben_Copeland
posted on 26/4/11 at 01:59 PM |
They'll be the same. Although i'm confused because your pictures are of the front not the back.
The Powerlite calipers are all the same, just brackets and discs differ.
The Rear Handbrake calipers are all the same, but not the same as the powerlites.
I think the only difference between the disc/drum kit is the drum one comes with the additional caliper mount holder.
Ben
Roadster
mads
posted on 26/4/11 at 06:43 PM |
Thanks Ben. The pics are of the front but I thought I'd ask about the back as I realised it was contributory to my problems. Have sent you a U2U
re: bits.
