mrwibble
| posted on 26/4/11 at 05:39 PM |
does this look right?
forgive my stupidity, but does it appear there is anything missing/wrong about these pictures
| posted on 26/4/11 at 05:44 PM |
The adjusters on the outer cable should butt up to the slotted tubes to give you your handbrake adjustment.
imp paul
| posted on 26/4/11 at 05:47 PM |
there seems to be a lack of prop lol
| posted on 26/4/11 at 05:58 PM |
The outer sheath of the cable needs to be retained by the slotted tubes to enable the handbrake to operate correctly.
Phil
Greenie
| posted on 26/4/11 at 05:59 PM |
Yes the hand-brake cables need to be located into the slotted shoulders and it appears they are the wrong way round the adjuster needs to go into the
one at the brear allowing access to the nurrled adjuster.....
40inches
And on the other side of the split tube.
avagolen
| posted on 26/4/11 at 06:03 PM |
Hi Mrwibble,
As ^^^^^^.
The cable end with the adjuster on it goes to the nearside wheel and it is best inserted in the lower tube,
while the offside end goes in the top tube.
I have made a bracket for mine which relocates the top tube to a lower position. (Picture shows it before welding.)
This has the effect of locating the end of the cable better.
HTH
Len.
  Offside_Handbrake_cable_bracke
  HandbrakeCable_2
[Edited on 26/4/11 by avagolen]
mrwibble
| posted on 26/4/11 at 07:45 PM |
thank you for your replies. very helpful. i will investigate further tomorrow.
