Author: Subject: My brakes don't work!!!
pekwah1
posted on 28/4/11 at 06:34 PM Reply With Quote
Hi Guys,
I got my last 2 brake lines in the post today so thought i should fill up the system!
However, only one of the resevoirs is pumping fluid.
As in the pic, only the 1st hole is getting fluid through, nothing coming out of the one at the end at all.
Should they both pump fluid out, or do i need to get the first line full of fluid before it will start putting fluid out of the 2nd?
I'm assuming they should both just work now, so any ideas of how i fix it?
Thanks,
jacko
posted on 28/4/11 at 06:42 PM Reply With Quote
It should come out both holes did you fill the tank sounds like the seals have a problem not sealing
Daddylonglegs
posted on 28/4/11 at 06:44 PM Reply With Quote
Certainly looks like the M/C may be foobarred
HomersDouble
posted on 28/4/11 at 06:45 PM Reply With Quote
Not sure on the answer Andy, but I have a spare Sierra M/C sat here at home in Pulborough you're welcome to try.
pekwah1
posted on 28/4/11 at 06:53 PM Reply With Quote
is that what mine is, a sierra one?
i'd love to rob yours off you to try! isn't lcb a nice place to be!
marcjagman
posted on 28/4/11 at 07:04 PM Reply With Quote
Yes it is
Pezza
posted on 29/4/11 at 05:37 AM Reply With Quote
Got a couple sat in the garage if yours is fubar'd mate.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
posted on 29/4/11 at 08:07 AM Reply With Quote
Sounds like the piston is stuck at full stroke ---- just a matter of cleaning, prime cylinder before fitting (use bleed nipples in port in ports to stop leaking.
pekwah1
posted on 29/4/11 at 11:26 AM Reply With Quote
ahhh, maybe i didn't prime it, that could be it.
the piston seems to be moving nice and freely.
What is the correct procedure for priming?
oh and pezza, failing all that i might have to take up your offer!
Pezza
posted on 29/4/11 at 12:57 PM Reply With Quote
no worries mate, just message me on here or FB if you need one.
