stevegough
posted on 4/5/11 at 08:07 AM |
Murdered my red-top yesterday.....
I have had a little mishap with my engine yesterday - You could call it 'self-inflicted' as just before going to stoneleigh, I bent my
brake and accelerator pedal arms to the right to give a better fit for my feet. It was better, but what I didn't realise, if I floored it, the
accelerator pedal could jam against the chassis rail. It did it once on the way to Stoneleigh, but freed off a second or two later. The second time
it jammed was on the way to work, but it freed off again easily - third time, it didn't! engine revving like crazy, had to declutch,
couldn't stop it - must have been 10 secs or so, approaching a busy junction - turned the ignition off - result - siezed engine.
So, anyone got a spare C20XE short engine (obviously, I've got all the ancilleries) ? I can come and collect and willing to pay
'reasonable money' for it - I dont want one I need to rebuild (I know my limitations!) but please ask around and see what's
available?
Cheers, Steve.
By the way, it was great to finally meet a few of you 'in the flesh' at Stoneleigh - Mel,(rusty nuts) the two Clives and their wives, Liz
and Sara,(Jollygreengiant and snuggs), Geoff (wilkingj), Beccy and 'feet'(Perci), tomgregory, neilP, kenton, steve lovelock, Paul(notts),
Ken555, RichardK(and the 'Bruise', Adrian (adithorp) and quite a few others. It was a great weekend.
Edited to add...I can come and collect, but obviously (to me, anyway) I don't mean the other end of the country - I would arrange a courier for
that.
[Edited on 4/5/11 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
adithorp
posted on 4/5/11 at 08:15 AM |
Bugger!
It ran so well on the way down a well... but I thought you were just having fun when you came flying past!
If it's now siezed it'll have bent a rod.
http://jpsc.org.uk/forum/
jossey
Shiiiittttt.
sorry to hear that mate.
glad your ok though.
plenty worse things could have happened with that happening.
good luck with your rebuild but jus be thankful your ok.
David Johnson
cd.thomson
posted on 4/5/11 at 08:25 AM |
glad you're okay steve,
hope you get it sorted quickly, at least it wont be as tricky as fitting an engine for the first time!
Craig
jollygreengiant
posted on 4/5/11 at 08:59 AM |
Sorry to hear of your tribulations Steve. Nice to have met you as well.
Glad you got home though.
I too had sticking throttle problems on the way home, however, it was not due to pedal or a sticking spindle. You know you commented about the ducting
and the hole in it, well, I found the missing bit that constituted the hole. It was trying to feed its self past the throttle butterfly.
Un-sucessfully I might add. Looks like I have some repairs/modifications to make. It looks like it was caused by a stone being thrown up onto it so I
shall have to replace the section and then I shall wrap it with a rubber type coating.
Hope you get sorted soon.
sevaun
posted on 4/5/11 at 09:46 AM |
Engine needed - I have one
Hi Steve
I have an engine and I've e mailed you.
Richard
karlak
posted on 4/5/11 at 10:36 AM |
No nothing about these engines etc, but did see this on another forum. He seems to think it is a bargain...
http://www.turbosport.co.uk/showthread.php?167462-Zero-Miles-2021cc-C20XE-Neil-Roper-Head-ARP-etc-etc-**Bargain**
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
nige
posted on 4/5/11 at 02:00 PM |
no good at links soz
but there is a short block on ebay with dry sump
it s title is vauxhall 2000 engine
good look mate
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
stevegough
posted on 4/5/11 at 02:14 PM |
good look mate
this one, you mean? VAUXHALL 2000cc engine block | eBay UK
Its quite a find, but I would need to rebuild the top of the engine, too - I'm not sure I'm up to that....
Thanks for the info, Steve.
Luego Locost C20XE.
stevegough
posted on 6/5/11 at 07:26 AM |
Thanks for all the heartfelt replies, Clive, Craig, Adrian and Jossey - you are quite right, it could have been so much worse.....
Cheers for the info and links, it looks like I am near enough sorted with a replacement, too thanks to sevaun.
Decided against the fancy one in your link, Karlak - it is a bargain, but I couldn't do full justice to it the way I planned to use it - it
would have been a waste.
Thanks and regards, Steve and the PHOENIX ! (I had been wondering what to call it......)
Luego Locost C20XE.
ken555
posted on 6/5/11 at 08:14 AM |
You need to update your footer
Luego Locost C20XE.
First IVA failed Dec 2010.
Retested + passed Jan 28th 2011.
New Engine required May 2nd 2011.
hucky
posted on 6/5/11 at 10:04 AM |
hey fella, may be worth keeping an eye on these to ebay links
VAUXHALL REDTOP ENGINE & ANCILLARIES C20XE / C20LET | eBay UK
rally race c20xe engine | eBay UK
the first one is very local to me, so if you need it collecting from the guy let me know and ill pick it up for you.
stevegough
posted on 6/5/11 at 02:20 PM |
Yes, thanks for the links, Hucky - I am watching the first one (and seven others) but the second one doesn't interest me - I've already
got one engine in need of a rebuild!
All being well, I should be picking one up this weekend in any case - the ebay ones are there as 'possibles'. Appreciate your surfing for
me, though.
Luego Locost C20XE.
stevegough
posted on 6/5/11 at 02:23 PM |
Luego Locost C20XE.
Yes, Ken - mine didn't last quite as long as yours, did it? Appreciate the humour, though......
Luego Locost C20XE.
stevegough
posted on 8/5/11 at 08:53 PM |
Thanks to everyone who posted links etc, I have now collected my replacement engine, (from sevaun in yorkshire) and I have commenced stripping out the
poorly one.....
.....carefully......
Luego Locost C20XE.
