Author: Subject: binding wilwood callipers
nib1980
posted on 6/5/11 at 07:42 PM Reply With Quote
hi all,
went for and passed MOT today but on the way home my new wilwiid callipers appeared to have bound on.
investigation shows the fluid is unable to leave once its in the circuit. i.e it can't return to the resouviour.
anyone got any ideas?
could it be a duff Master cylinder?
many thanks
p.s. there all new...
austin man
posted on 6/5/11 at 07:49 PM Reply With Quote
no play in the rod from the pedal to the cylinder, there should ne some play otherwise the return circuit will be partially closed and the brakes on this will get worse with the fluid heating and expanding
posted on 6/5/11 at 07:58 PM Reply With Quote
Also check for a sticking brake pedal
nib1980
posted on 6/5/11 at 08:00 PM Reply With Quote
when you say some play how do you mean?
austin man
posted on 6/5/11 at 08:12 PM Reply With Quote
there should be a small amount of movement before the rod pushes the piston therefore free movement there could be a stone under the pedal
nib1980
posted on 6/5/11 at 08:14 PM Reply With Quote
gotcha ill check in the morning!
madteg
posted on 6/5/11 at 08:37 PM Reply With Quote
Small return hole in master cylinder blocked.
[Edited on 6/5/11 by madteg]
nib1980
posted on 6/5/11 at 08:49 PM Reply With Quote
How do I find and check that?
ReMan
posted on 7/5/11 at 07:27 AM Reply With Quote
Small stone stuck under brake pedal floor stop?
(Happens to me now and again)
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
