hucky
| posted on 11/5/11 at 05:51 PM |
cortina brakes
i have a set of cortina uprights and looking at poss fitting some peugeot 306 gti calipers. these fit onto the up rights fine, will just need spacing
back a little. but i need some vented discs about 260ish mm maybe a touch more..
anyone know if they make some?
cheers
chris
| posted on 11/5/11 at 06:15 PM |
ISTR Peugeot calipers almost fit the hole pitch is about 2 mm out.
phelpsa
| posted on 11/5/11 at 06:35 PM |
Fit perfectly on my cortina uprights! I'm running the ali bodied bendix ones with early base model cortina (241x9.5) discs though.
spiderman01980
| posted on 11/5/11 at 06:55 PM |
Capri 2.8i vented discs!
phelpsa
| posted on 11/5/11 at 06:56 PM |
....are only 240mm (or 245?) diameter.
spiderman01980
| posted on 11/5/11 at 07:02 PM |
What about Ford focus 4 stud discs!?
phelpsa
| posted on 11/5/11 at 07:30 PM |
Dont fit the hub.
I'm sure one of the wilwood kits uses a 260mm disc now I think about it!
Doctor Derek Doctors
| posted on 11/5/11 at 07:39 PM |
You could get some 306 GTI-6 discs (they are quite cheap) which have the correct 108pcd and them skim them down from 283mm to 260mm in a lathe.
Myke 2463
| posted on 11/5/11 at 07:48 PM |
Sierra 2.0 autos and xr4i use 260mm instead of the std 240mm and vented.
Be Lucky Mike.
hucky
| posted on 12/5/11 at 10:04 AM |
my major problem is finding what will bolt to the hub, but thank you for the ideas, i will order them in and see what fits
cheers everyone for the very quick responce
b14wrc
| posted on 12/5/11 at 11:07 AM |
Try looking at 406 coupe 2.2, they are of a 283mm size and have a useful off set off 2mm which will bolt to the back of the hub in the same way as the
original did.
Look at some threads i did, i want to use brembo calipers on mine.
Rob
20vt powered rear engined locost
phelpsa
| posted on 12/5/11 at 11:09 AM |
None of the sierra etc discs will work.
The only thing i can think of is that peugeot discs are quite low offset. You might be able to redrill them to mount onto the back of the hub
properly. Other than that custom discs could be the only way.
EDIT: Wow, great minds think alike!
[Edited on 12-5-11 by phelpsa]
hucky
| posted on 12/5/11 at 12:30 PM |
was looking at that, the sierra discs come and a few others but none will bolt up the way i need. the peugeot one will fit if redrilled i think. but
also centre bore drilling out a little.
may have to look at the saxo vtr brakes i have knocking about somewhere, see how they line up with the cortina discs before i start hacking away at
everything
b14wrc
| posted on 12/5/11 at 06:01 PM |
Lol.... Great minds do think alike!
I have looked into this quite a bit, look for the tread on here regarding 300mm discs, my conclusions came to the 406 coupe non Brembo discs which I
reckon will bolt on from the back and I should get away with 15's using the fiat coupe calipers on the cortina hubs.
[Edited on 12/5/11 by b14wrc]
