alainmengoli@hotmail.com
posted on 18/7/04 at 05:00 PM |
hung pedal box
Basically i need a hung pedal box with bias brakes and hydraulic clutch. i sthere anything in the market that is available not wilwood nor tilton as
they ar every expensive. Does the SVa require them to be of a specific design or thickness ( is it possibble to build one)????
Mark Allanson
| posted on 18/7/04 at 06:16 PM |
Its not biased, but there is loads of room to fit an additional cylinder. Remote resv as well!
[Edited on 18/7/04 by Mark Allanson]
TheGecko
| posted on 19/7/04 at 02:41 AM |
That looks like the sort of thing I'm after. Any chance of telling us what it's out of or am I missing something here?
Dominic
| posted on 19/7/04 at 06:01 AM |
yep same here and are you selling it how much?
DaveFJ
| posted on 19/7/04 at 08:12 AM |
seen this ?
http://www.locostbuilders.co.uk/viewthread.php?tid=15459
better be quick - 36 mins left !
[Edited on 19/7/04 by protofj]
Dave
| posted on 19/7/04 at 09:18 AM |
but no hydraulic clutch
derf
| posted on 19/7/04 at 01:00 PM |
Not sure if this helps, but:
  Pedal box
I havent added the gas pedal yet, but it will be cable operated, and will bolt directly to the chassis.
DaveFJ
| posted on 19/7/04 at 01:34 PM |
It was modified for hydraulic clutch - a bit late now though......
Dave
| posted on 19/7/04 at 03:01 PM |
I just bought a tig welder and thought of building my own bt am worried about sva requirements.
Mark Allanson
| posted on 19/7/04 at 08:15 PM |
alain, I thought you would have guessed!! X19 again, it wont fit a locost with the column running above the chassis, but would be OK if you ran it low
down MK style.
I still have it in my aborted ideas box, but a little to heavy to post, but if any one is coming down on holiday, they can have for what I paid for it
- £3.00 - but I'm open to offers
| posted on 21/7/04 at 09:17 PM |
what you guys think of this idea but not sure where to ge the bias parts and bushes. Does the steel thickness have to be to a sva
requirement?
| posted on 21/7/04 at 09:18 PM |
oops very big and only good for the southern hemisphere.
