alistairolsen
| posted on 17/5/11 at 08:56 AM |
Brake bulkhead fittings and locost brake fittings in general...
First off I'm looking for a locost supplier of brake fittings. I have male nuts, but things like tees seem to be about £6 each on ebay! Anyone
got any good suppliers?
Secondly I need some fittings to cross a bulkhead, ideally to clamp into thin steel and offer a connection on each side. Has anyone seen anything like
this which is acceptable for use on brakes?
My Build Thread
Ben_Copeland
| posted on 17/5/11 at 09:27 AM |
What brake flexies are you using as they using come with bulkhead fittings fitted. Well the ones i've made up do anyway.
these...
Male bulkhead convex seat hose fitting - (3/8 x 24 UNF) or
Male bulkhead convex seat hose fitting - (M10 x 1)
or you can use these....
Hose Fitting M10 x 1 to M10 x 1 male/male bulkhead fitting
[Edited on 17/5/11 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Ben_Copeland
| posted on 17/5/11 at 09:30 AM |
Or are you talking about copper lines through the bulkhead???
I which case why bother, just run it through a hole
Ben
Roadster
alistairolsen
| posted on 17/5/11 at 10:03 AM |
Its a saloon car and I need to come up through the floor to bias valve and handbrake and then back down and would prefer not to need a second person
to hold the other side if I ever need to undo the lines.
Bottom ones pictured look good, just make the lines up with female nuts and clamp those in place with a halfnut?
Where did you get them?
My Build Thread
Ben_Copeland
| posted on 17/5/11 at 10:19 AM |
Those ones are rally design. £3.50 ish plus vat. But you need the nut aswell
Ben
Roadster
mrwibble
| posted on 17/5/11 at 10:37 AM |
dont know about the second bit, but motor factors would be my first reaction. plus russbot on here knows his brakes.
