dan_g8
posted on 17/5/11 at 10:03 PM |
anyone have side panel dimensions?
Does anyone have a set of dimensions to make the side panels or know where i get some ? i need to draw up a couple of templates for the origional
locost - ron champion chassis. i have had a quick search on here but i can only find pictures of how people have done it and not actual dimensions.
Dan
James
posted on 17/5/11 at 11:02 PM |
I dont know if this is any use is it?
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=bracketjig1.jpg
I think your problem is that the shape of the panels varies quite a lot. You can get the basic dimensions (height and length and the position of the
fold in the panel but there are many variables. How your nosecone is shaped will have an effect, as will the placement of wishbone brackets and
steering rack.
As far as I know, most people do it with templates that they transfer to their ali sheet.
Hope that helps,
James
- Muhammad Ali
Confused but excited.
posted on 17/5/11 at 11:04 PM |
The book is a good place to start.
jonrotheray
posted on 17/5/11 at 11:11 PM |
Hi again Dan
The original book has a drawing for the front part - I can scan that, and there are some pretty good drawings of the chassis which might help. Sorry
I didn't get back to you before!
As these are pdfs I can't put them in the aarchive but I've emailed them to you.
Jon
gavin174
posted on 18/5/11 at 08:45 AM |
Dan
You need to be a bit careful, as unless you do your own drawing they could well be copyrighted
Cheers Gavin
dan_g8
posted on 18/5/11 at 12:22 PM |
quote: Originally posted by jonrotheray
Hi again Dan
Jon
Thanks Jon, ill get these drawn up and let you know when they are done if you are still interested. I have had a few other people asking about these
aswell.
Dan
macc man
posted on 18/5/11 at 02:09 PM |
I found the best way is to make your own template out of thin card or wallpaper. That way you can allow for all the fiddly bits up front. I made mine
in two pieces for easy bending but it is possible to make in one go. once on car make sure you trial fit wishbones for clearance or you will need a
good file.
