<<  1    2  >>
Author: Subject: Front Shocker top mount ?
Trollyjack
posted on 30/5/11 at 09:41 PM Reply With Quote
Hi
I have assembled the front end to day and now deciding where to put the top shocker mount
Do I put it on the side of the top rail
In both positions I am getting about 40mm of travel on the shocker
Or under side of top rail
On side of top rail
On side of top rail
Been told they are best stood up but please comment
I think under side would be better and more consealed
Comments welcome Please
There are more photos in my photo archive under front end
TrollyJack
Chippy
posted on 30/5/11 at 10:11 PM Reply With Quote
I would mount it under the chassis rail for two reasons, 1/ it looks neater, and is better for IVA. 2/ you will get "slightly" more travel as its on more of an angle. HTH Ray
tilly819
posted on 30/5/11 at 10:22 PM Reply With Quote
In the ideal world it should be placed were the load path passes through the center of the supporting chassis rail
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
blakep82
posted on 30/5/11 at 10:28 PM Reply With Quote
tilly
personally i'd have brackets like this
with either of your options, you're never applying a sort of compression force, its always trying to push the brackets away from the tube
________________________
Jon Ison
posted on 30/5/11 at 10:37 PM Reply With Quote
Mine are as your lower photo but connected to each end of a rail that is welded to the underside of the upper chassis rails, also cross braced to the bottom rails. Well I know what I mean........
Trollyjack
posted on 30/5/11 at 10:55 PM Reply With Quote
Was thinking of lining the top eye around here and putting a channel across from the outer toprail the the cross support thar is 5" inside.
TrollyJack
posted on 31/5/11 at 08:36 AM Reply With Quote
Better on the outside of the rail to keep it more upright. More angle needs stronger springing.
Badger_McLetcher
posted on 31/5/11 at 12:30 PM Reply With Quote
IIRC if you place them on the inside of the chassis you'll get a more pronounced spring fall off rate- the more vertical the better.
Doctor Derek Doctors
posted on 31/5/11 at 12:42 PM Reply With Quote
Instead of just guessing you should sketch it up and check the installation ratio / suspension rate, really you want it to have a constant or 'rising rate'.
I.E for every 1mm of the wheel the shock compresses by Xmm, ideally with X being constant or increasing for each consequtive mm of wheel movement.
If you don't check and have X decreasing for each mm of wheel travel then you will end up with some very odd handling, especially in roll.
This is very basic input though.
Is this position not defined in 'the' book?
[Edited on 31/5/11 by Doctor Derek Doctors]
Trollyjack
posted on 1/6/11 at 10:31 AM Reply With Quote
Looked in Book and it does not say where to mount the top mounting brackets
some pictures show on side of top rail and some photos show it under side of top rail ??
TrollyJack
posted on 1/6/11 at 12:48 PM Reply With Quote
If you get me the following dims I can sketch it up for you in CAD:
Length of lower wishbone pick-up to lower shock mount
Angle between the line (between the above two points) and the horizontal Plane (floor)
The distance between the lower wishbone mount and the center of the chassis top rail.
Angle between the line (between the above two points) and the horizontal plane (floor)
Open and closed length of the shock
Overall length of the lower wishbone.
A simple sketch that I have knocked up will tell you the installation ratio in seconds and also if you have rising/falling/constant rate in various positions and then you can make an informed decision.
Trollyjack
posted on 1/6/11 at 03:27 PM Reply With Quote
Thats Brill
I'll measure next time i'm at my lock up
Kev
TrollyJack
Bare
posted on 1/6/11 at 04:56 PM Reply With Quote
Simply Try to mount the shocker unit as vertically as absolutely possible. ..
Save yourself a maths exercise to tell you exactly that .
Wouldn't overly worry about structural 'niceities' as even the suspension pickup points on these Locost chassis are just daft/poor . The mount ears have been documented to fatigue off due to their poor placement and inadequate support.
Shock mount 'strength' is the least of your worries.
[Edited on 1/6/11 by Bare]
Trollyjack
posted on 1/6/11 at 09:08 PM Reply With Quote
to Doctor Derek Doctors
Length of lower wishbone pick-up to lower shock mount = 225mm
Angle between the line (between the above two points) and the horizontal Plane (floor) = 0°
The distance between the lower wishbone mount and the center of the chassis top rail. = 270mm
Angle between the line (between the above two points) and the horizontal plane (floor) = 74°
Open and closed length of the shock = 320mm open 255mm closed with rubber bump stop 235mm with out
Overall length of the lower wishbone. 340mm to centre od bottom ball joint.
I have drawn it up on a cad package but not ver good at it yet I can email you the DFX file if you wish
TrollyJack
posted on 2/6/11 at 09:32 AM Reply With Quote
I made a sketch yesterday, I'll stick the numbers in at lunchtime and test some positions.
I will test for Inside, Outside and Below the rail and tell you the rate, and rate change.
paulf
posted on 2/6/11 at 09:48 AM Reply With Quote
I had the same dilemma when i built mine and remember something about the mounting bolt being hard to fit when under the chassis rail as it was tight to the Fu tubes.I fitted the brackets to the outside of the chassis rail and made a wedge section that fitted between the rail and bracket to make it parallel to the lower mounting bracket .I thought the shock being more upright was the best way to have it and as mentioned the spring rate can be lower and wont tend to end up as a falling rate as could happen if mounted under the rail and to far in board.
Paul
posted on 2/6/11 at 02:15 PM Reply With Quote
Right then.
With those dims you cant put the shock directly inline with the chassis rail as you will have a very high ride height or your shock will be nearly fully compressed to keep that angle of the wishbone.
I have made an assumption that the centre of the shock top mount will be 40mm away from the centre of the chassis top rail (to give clearance) and that you will have 30-35mm of droop and 60-65mm of bump.
Inside mount:
-30 = 312.783
-20 = 307.713 = 5.07
-10 = 302.579 = 5.134 = 0.064
0 = 297.38 = 5.199 = 0.065
10 = 292.118 = 5.262 = 0.063
20 = 286.792 = 5.326 = 0.064
30 = 281.402 = 5.39 = 0.064
40 = 275.947 = 5.455 = 0.065
50 = 270.429 = 5.518 = 0.063
60 = 264.846 = 5.583 = 0.065
Outside Mount:
-30 = 315.486
-20 = 309.505 = 5.918
-10 = 303.469 = 6.036 = 0.118
0 = 297.38 = 6.089 = 0.053
10 = 291.328 = 6.052 = -0.037
20 = 285.044 = 6.284 = 0.232
30 = 278.798 = 6.246 = -0.038
40 = 272.502 = 6.296 = 0.05
50 = 266.157 = 6.345 = 0.049
60 = 259.762 = 6.395 = 0.05
The first number is the suspension travel (- = droop, + = Bump) The second number is the shock length, the third number is the change in shock length and the forth number is the change in shock rate.
In my conclusion mounting inside will give roughly a 5:10 installation ratio, mounting outside will give a 6:10 installation ratio thus outside would be stiffer with the same springs.
What's interesting as that mounting inside gives a lovely constant (amazingly constant) figure for the rate increase (0.063-0.065mm) over the entire travel of the shock which is ideal, whereas the outside mounted shock has a very erratic change of rate (-0.037-0.232mm) which will give odd handling.
If it was my car I would mount the shock inside to give more constant and progressive damper/spring travel with a constant rate increase, it will also allow you to have a longer wheel travel (also more ride height adjustment) and it will be a much neater finish to the car.
Hope that helps.
Trollyjack
posted on 2/6/11 at 07:21 PM Reply With Quote
So are you saying that the top mount is to be inside the top rail
where exactly is it to be, on the centre line of the top rail or under neath ?
could you you email me a sketch Please
TrollyJack
posted on 3/6/11 at 07:20 AM Reply With Quote
I have screen grabbed the sketch, here and in my archive
Basically though if you keep the wishbone inner pivot to - lower shock mount line at 0° (as you specified), extend to the shock to 295-300mm (297.38mm in the sketch) and then put the top mount so it sits 40mm from the centreline of the top rail you'll have what I used.
The two double white circles are the top and bottom shock mounts, the 25x25mm square box is obviously the chassis top rail and I I'm sure you can work out the rest.
Trollyjack
posted on 3/6/11 at 08:50 AM Reply With Quote
Thats brilliant thanks very much for you time, it has been much appreciated
By luck my idear was not too far away
now to manufacture the top bracket I intent to make this out of Stainless to give it better strength.
TrollyJack
posted on 3/6/11 at 09:30 AM Reply With Quote
No Probs mate, I tried to base it on your initial projections to make something manufacturable.
Have fun building, I wish I could get some time to do some practical work rather than being in front of the desk.
posted on 3/6/11 at 09:35 AM Reply With Quote
....or spend 30 mins doing some maths and find out that doing that would have given poor, inconsistent geometry.
[Edited on 3/6/11 by Doctor Derek Doctors]
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Neville Jones
posted on 3/6/11 at 10:00 AM Reply With Quote
That statement above is about right on every count. What oriface DDD pulls his info from I don't know,( Wikipedia?or the same place as the ship's engineers?) but as the shock inclines from the vertical, once you get past about 10 degrees, things start to go way past non linear in the non desireable direction.
The locost setup puts some limits with the top wishbone design, and clearance for the coilover setup.
There are other ways of mounting the top shock bolt. I'll try and post a pic.
And yes, accepted practice among knowledgeable suspension designers would be to mount the shock as close to vertical as possible, with enough inward inclination to give a rising rate up to the point of max bump, where the shock would be 90 degrees to the wishbone.
Well, that's how the couple of designers I've met would do it.
Nev.
flak monkey
posted on 3/6/11 at 10:11 AM Reply With Quote
Nev.
Absolutely correct
Sera
http://www.motosera.com
Fred W B
posted on 3/6/11 at 11:11 AM Reply With Quote
Please don't make the brackets from stainless unless you intend to use the correct consumable to weld it to carbon steel.
Stainless is alloyed to give certain properties, if you dilute the alloys (by welding to carbon steel) you end up with the wrong structure and form a brittle rather than ductile weld.
When welding with 316 use 316 electrodes, when welding with 304 use 309 (best) or 316 electrodes.
You would be much better off to make the bracket in thicker carbon steel if you want it stronger.
Fred W B.
[Edited on 3/6/11 by Fred W B]
<<  1    2  >>
