femster87
| posted on 9/6/11 at 08:05 PM |
wheel speed sensor
Any Ideas for mounting wheel speed sensor on sierra upright. This is for the dash 2 sensor. Pictures would be great.
franky
| posted on 9/6/11 at 08:11 PM |
I mounted mine on the diff, reading off the prop. Could you put yours there?
femster87
| posted on 9/6/11 at 08:12 PM |
I have got the space, so I should be able to. Just initially though I would like it to read the actually speed of the non driven wheel.
You got a picture of your contraption franky?
[Edited on 9/6/11 by femster87]
franky
| posted on 9/6/11 at 08:18 PM |
I've not got a pic, just welded a bar to the top of the diff so the hall sensor was looking at the bolts where the prop bolts to the flange.
big_wasa
| posted on 9/6/11 at 08:35 PM |
If you put it on the front hub you may have problems with iva as they check speedo on the rollers.
femster87
| posted on 9/6/11 at 08:41 PM |
Did not think about that Warren, thanks. Guess I would just put it on the prop.
franky
| posted on 9/6/11 at 09:02 PM |
I guess but why can't they put the front wheels on?
stevegough
| posted on 9/6/11 at 09:14 PM |
I've got one of mine if it helps - aluminium bracket secured to rails using rivnuts, speed sensor in the centre, magnet mounted on the prop
using some of that stuff a bit like blu-tac but sets like metal.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
franky
| posted on 9/6/11 at 09:18 PM |
That looks like a good way of doing it. I had a problem where the diff moves though as its on bush's and it would drop out so I guess how the
diff is mounted alters things too!
ETA I see you're using a magnet, i'm using a hall effect so have to look at bolt heads.
[Edited on 9/6/11 by franky]
femster87
| posted on 9/6/11 at 09:27 PM |
I would be using hall effect sensor as well. so would have to be bolts. Thankd for the image I would use the same idea to mount the sensor
stevegough
| posted on 9/6/11 at 09:39 PM |
True, My diff is fixed. You would have to mount the bracket to the diff itself, I suppose - or maybe at the front of the prop, but there's no
bolt-heads at that end....
Luego Locost C20XE.
mad-butcher
| posted on 10/6/11 at 07:51 AM |
Acewell Type 1 screw in magnet
4 magnet Type
mounting it on the rear upright saves having to add the diff ratio reduction into the calibration calculation
tony
femster87
| posted on 18/6/11 at 03:36 PM |
thanks tony
beaver34
| posted on 18/6/11 at 09:46 PM |
I'm on cortina uprights, mine in one of the holes in the front lines up with the stud heads on the hub
matt_gsxr
| posted on 18/6/11 at 10:39 PM |
When I took the SVA the rollers for the speedo test were non-powered, so they couldn't measure the speed of the front wheels (except at
0mph).
The brake testing hardware is different (driven) so I don't know why they have to have two sets of rollers.
If you have a front wheel sensor then they can find ways of testing, but they can also be difficult about it.
