mcg
| posted on 25/6/11 at 12:57 PM |
pls confirm correct diff oil?
Hi -
Following previous threads, please can you confirm that the diff oil I have bought is correct? I have a 3.62 LSD.
I know that I need an EP 90, but I thought it was a normal diff oil (not LSD specific), but at a 90. The only reason for my doubt is that it actually
says LSD diff oil on the container.
Thanks in advance
Matt
Chippy
| posted on 25/6/11 at 03:39 PM |
Can't recall what the recomended is for the Ford diff, I just use EP80/90 seems to work fine. I would think that the one you have will be OK,
although the LSD in the Ford diff is sealed so dosen't need special oil, it is filled with a viscous fluid. HTH Ray
Just checked the book, and that states EP90, so your stuff is by the book. Cheers Ray
[Edited on 25-6-11 by Chippy]
