planetester
| posted on 24/7/04 at 08:06 PM |
Axle mod (book dimensions)
This must have been asked before but I cant find the answer,
Page 72 shows a line passing thro the mounting bolt holes level with the diameter of the axle, it also shows the center of the axle level with the
edge of the bracket & the trailing arm holes roughly in the center of the bracket,
pages 73 & 64 show the trailing arm holes forward of the diameter of the axle,
which is right
thanks in advance
Mark Allanson
| posted on 24/7/04 at 08:19 PM |
There are no rights and wrongs in the book (sorry, correction - there are lots of wrongs). Put them where you like, but check your final axle position
and the length of the trailing arms if you have them. I put mine behind!
DavidM
| posted on 24/7/04 at 09:31 PM |
I put mine behind too, as page 72.
Mark, may I ask where you got those brake pipe clips from?
planetester
| posted on 24/7/04 at 09:40 PM |
Hi, thanks for your reply, Ive bought a Stuart Taylor chassis & arm set, his arms are 13" long, the book says 12" ??
Ive just made these, are they like yours
thanks
Mark Allanson
| posted on 25/7/04 at 08:05 PM |
Just about identical
planetester
| posted on 25/7/04 at 08:33 PM |
Thanks Mark, Its good to know that I dont have to remake them, All I need to do now is to see what differance the Stuart Taylor trailing arms will
make at 13" long
thank again
Mark Allanson
| posted on 25/7/04 at 08:59 PM |
Fuel line clips from ford, brake pipe clips from peugeot, I said they wre for my car and free samples arrived next day! (it's nice having a 30K
parts budget at my desposal   )
DavidM
| posted on 25/7/04 at 10:47 PM |
Cheers Mark.
| posted on 26/7/04 at 08:07 AM |
The longer trailing arms will just mean you have to put another inch on the propshaft. I've made my new ones an inch longer to move the wheels
back a bit in the rear wings. It shouldn't make a lot of difference to anything else unless it puts a bit of angle on the rear dampers.
planetester
| posted on 29/7/04 at 09:48 PM |
spoke ti Ian Grey at ST & he says that the dims in the book are wrong & 13 is correct so I'll carry on building & see what happens
