Author: Subject: Rear wheel hubs from new FWD cars?
adithorp
posted on 18/7/11 at 12:46 PM Reply With Quote
I had a Vaux' Insidious in work on Friday and noticed the rear hubs are splined to take a driveshaft. They're FWD so I assume this is for 4WD versions or they're utilising the same bearing carrier/hub assembly on the rear, as they use on the front. I'm pretty sure I've seem similar hubs used on other cars/makes as well.
Has anybody looked into using these on a kit?
http://jpsc.org.uk/forum/
matt_gsxr
posted on 18/7/11 at 01:45 PM Reply With Quote
Adi,
Imagine going into your local spares place and asking for a CV joint for the back of a front wheel drive car.
There would be more than the normal sucking of teeth!
I guess you could use the diff too
posted on 18/7/11 at 02:00 PM Reply With Quote
Be intersting to know what ratio it is!
rallyingden
posted on 19/7/11 at 04:09 PM Reply With Quote
What model is that pic of as I have tried searching
RD
Confused but excited.
posted on 19/7/11 at 04:46 PM Reply With Quote
Opel version of a Vauxhall Insignia.
Liam
posted on 19/7/11 at 04:47 PM Reply With Quote
RD
Insignia estate
stevebubs
posted on 19/7/11 at 06:04 PM Reply With Quote
Interestingly it's available as an extra on pretty much every engine variant...so there may be a nice selection of ratios...
