shindha
| posted on 23/7/11 at 04:25 PM |
Hub Nut Size??
Hello All,
I have Westfield rear uprights these take the Sierra half shafts and hub nuts. I need to know what size are these as the 41mm is a bit loose and the
40mm is tight - or do I need to knock the 40mm on with a hammer or is it some wonderful AF size.
Thanks for looking and for any replies.
Shindha
macc man
| posted on 23/7/11 at 04:48 PM |
I had the same issue so I filed the flats on the nut to suit the socket I had. 40 mm.
adithorp
| posted on 23/7/11 at 05:29 PM |
Should be 41mm
http://jpsc.org.uk/forum/
