dan_g8
posted on 24/7/11 at 03:14 PM |
Wtd - 2 small Parts turned in steel
Hi all, im after 2 parts to be turned out of steel, its for a release bearing spacer. Part B needs to fit inside Part A so needs to be a fraction
smaller than 42mm.
See below for a pic, all dims in mm. let me know your price.
Thanks in advanced
![](/galpreviews/spacer2.jpg) ![bearing_spacer](/gallery/spacer2.jpg) bearing_spacer
[Edited on 24/7/11 by dan_g8]
PSpirine
posted on 24/7/11 at 05:21 PM |
Might help if you specify how it's meant to fit
If it fits in and stays there, then why not just make a one-piece spacer?
If it's supposed to be able to slide within it, then you need to work out your tolerances!
Myke 2463
posted on 24/7/11 at 05:39 PM |
Flak_monkey is your man, http://www.customworkshop.co.uk/
Be Lucky Mike.
dan_g8
posted on 24/7/11 at 05:49 PM |
Thanks Myke, ill give flak_monkey a try.
The 2 parts wont stay together for long, part b is a guide so will be removed once part a is in place/ attached.
