Author: Subject: 4 pot brake Plumbing?
posted on 29/9/11 at 03:44 PM Reply With Quote
Whats the best way to plumb 4 pots that have two lines into each caliper from a master cylinder with only one output?
Just a matter of splitting at the top down each side of the car then in two again into each caliper?
I have Range Rover calipers, which look exactly like Princess 4 pots, and a Suzuki SJ master cylinder
mookaloid
posted on 29/9/11 at 04:22 PM Reply With Quote
Can't see why not
RichardK
posted on 29/9/11 at 04:29 PM Reply With Quote
That's how I'd do it.
R
P.S did you ever find out how your vvt works?
Gallery updated 11/01/2011
v8kid
posted on 29/9/11 at 04:32 PM Reply With Quote
Ummm! I'm stumped. Is it a recirculating system where the fluid goes in a loop to make sure any bubbles are driven off in the master cylinder or are the links between each side that are normally part of the calliper missing? I'd check the donor manual if I were you.
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
posted on 29/9/11 at 04:47 PM Reply With Quote
Cheers!
These calipers are designed for a superior split circuit design, if a single circuit fails you still have half of the front calliper pistons working which is much better than a diagonal pair (or even worse only the rears).
The Metro had a system like this, and when people used these calipers on minis the two ports were linked together with a small aeroquip pipe on the caliper. Not saying that's the nicest method though.
posted on 29/9/11 at 05:17 PM Reply With Quote
Two lines in, 3 bleed nipples, no external links. I know on the rangy they were a dual, split powered system but I aint going to be carrying that much weight!
phelpsa
posted on 29/9/11 at 06:15 PM Reply With Quote
Are you planning to mount them with the inlets at the bottom? You may have some bleeding issues if you dont.
You can use a kunifer pipe from the bleed nipple port on one part of the calliper to the inlet of the other part, that way you have one hose, one inlet and one bleed nipple.
[Edited on 29/9/11 by britishtrident]
phelpsa
posted on 29/9/11 at 06:16 PM Reply With Quote
And a hell of a time trying to bleed them
posted on 29/9/11 at 06:19 PM Reply With Quote
Not really ---- i can never understand why brake bleeding seems to cause such issues for people.
posted on 29/9/11 at 06:44 PM Reply With Quote
Nope, they are going back on the axle at the original position.
posted on 29/9/11 at 06:45 PM Reply With Quote
Nice idea, but, how do I work out which one to be sure the fluid acts on all 4 pistons? The one furthest away eg??
slingshot2000
posted on 29/9/11 at 07:09 PM Reply With Quote
Coozer, this is how I remember Princess calipers were plumbed when I fitted a pair to my MK2 Escort. My brother and I realised that they were remaekably similar to Range Rover calipers, so sat some side by side to compare them. They are so close you could not see any difference, however the mountig holes were ever so slightly different ( this ruined my idea of flooding the Old School Ford market with recon Rangie calipers). Also, Range Rovers with vented discs use the same calipers but spaced from the factory, just as I had to do to fit vented discs to my Escort.
Regards
Jon
posted on 29/9/11 at 07:21 PM Reply With Quote
You and Brian know how to plumb them up for a single line Jon??
slingshot2000
posted on 29/9/11 at 08:00 PM Reply With Quote
I will speak to Brian tomorrow, it is a while since I did them and hes till working with them every day.
Regards
Jon
slingshot2000
posted on 29/9/11 at 08:02 PM Reply With Quote
P.S.are you still after some KillKenny? Dad is across the water justnowand could probably arrange a shipment.
posted on 29/9/11 at 08:11 PM Reply With Quote
Yes mate, I would appreciate that. You going to Brians tomorrow? I may have a run over in the morning to see him about the upper A arm ball joint.
slingshot2000
posted on 29/9/11 at 08:15 PM Reply With Quote
Give me a txt if your going, I will be about and it would be good to see you again. I have been meaning to contact you to see if your going to Richardk's curry night.
Regards
Jon
posted on 29/9/11 at 08:19 PM Reply With Quote
Open the nipples and blow through with low pressure air.
