derf
| posted on 10/8/04 at 01:27 PM |
What is this?
I just finished one side of my front suspension last night, and realized that I had bought the wrong ball joints (the spindle is upside down), not too
much of a problem, I'll just get the correct ball joints and check to see if I need to adjust it. Then today I notice while flipping through the
archives some people have a rubber of some sort on the ball joints, am I supposed to have this? The only rubber I had was the boot that keeps the
grease in the joint, bt the one pictured here looks more like a bumps stop? Or am I just so tired I'm seeing things that dont exist?
locoboy
| posted on 10/8/04 at 01:40 PM |
things exist but WE cant see them!
Locoboy
stephen_gusterson
| posted on 10/8/04 at 01:45 PM |
been down the pub colm?
atb
steve
locoboy
| posted on 10/8/04 at 02:09 PM |
I wish!
The piccy is not showing on my machine, am i the only one?
Hic!
Locoboy
stephen_gusterson
| posted on 10/8/04 at 02:42 PM |
i cant see, i cant see.......
atb
steve
quote: Originally posted by colmaccoll
I wish!
Hic!
[Edited on 10/8/04 by stephen_gusterson]
locoboy
| posted on 10/8/04 at 02:53 PM |
stephen_gusterson]
And that young man has nothing to do with your computer
Locoboy
derf
| posted on 10/8/04 at 04:08 PM |
Th evil red X struck again, I'll try and find the photo again, but it looked like a squished rubber bushing between the upper ball joint and the
spindle
derf
| posted on 10/8/04 at 04:12 PM |
  Alloy wheels inside
theconrodkid
| posted on 10/8/04 at 05:49 PM |
you been eating dodgy mushrooms?looks normal cortina to moi
who cares who wins
pass the pork pies
andkilde
| posted on 10/8/04 at 05:51 PM |
Hey Derf
Do you mean the little foam donut that occasionally comes with a "premium" ball joint?
AKAIK they're just an extra deal to protect against road grime -- usually fit between the ball joint and the upright. All the one's
I've seen are too soft to provide any ability to act as a bump stop.
If it's something else, ignore me
Cheers, Ted
derf
| posted on 10/8/04 at 06:05 PM |
The ones I bought came with rubber boots to keep the grease in, but these looked like they could actually provide some comfort, like they were solid
poyurethane
twinturbo
| posted on 10/8/04 at 11:19 PM |
Sounds like a protective cap that your supposed to take off and place in the bin.
TT
| posted on 11/8/04 at 12:02 AM |
Would that be after you've used it then? The only bump stops of any use would be in the damper stem. It's just a dust seal.
[Edited on 11/8/04 by Peteff]
twinturbo
| posted on 11/8/04 at 08:46 AM |
Ball joints often come with a plastic protective cap ( often milkey white ) which should be removed before fitting. It is there to vrevent damage to
the rubber during storage, handeling..
If it's left in place it will prevent the joint from moving.
TT
James
| posted on 11/8/04 at 08:57 AM |
That picture is Jaspers car.
It's just a fiver-a-pair set of BJs from Lolocost!
The bulge bit you can see is just the grease boot.
HTH,
James
