Tris
| posted on 10/11/11 at 10:27 PM |
Sizing rear brake discs on IRS fury
Hi all,
In the process of converting the rear brakes on my fury from drums to disc. Got myself a couple of wilwood powerlites (with handbrake), and now I need
to get some discs.
What size of disks are best to use when using 13' rims ?
Tris
rdodger
| posted on 10/11/11 at 10:45 PM |
The wilwood sierra rear kit uses a 240 x 10mm mk3 escort disc for 13" wheels.
[Edited on 10/11/11 by rdodger]
matt_gsxr
| posted on 10/11/11 at 10:53 PM |
as above, but you will need to modify the hub.
Tris
| posted on 10/11/11 at 11:14 PM |
Great, thanks both for the info
wilkingj
| posted on 10/11/11 at 11:39 PM |
Make sure you dont "OverBrake" the rear, I failed my SVA twice on this, by having std sierra 240mm discs on the front (off a rear drum
braked sierra) It failed on the back to front ballance.
I eventually got it to SVA, with the ballance bar almost full over.(rule of thumb is fronts lock up before the rears)
Later on I fitted the 260mm fronts of a 4x4 Sierra. All nice and even now.
Just make sure its ballanced properly or you could have problems.
Braking is a "Mission Critical" component on the car, Make sure you get it right.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 11/11/11 at 08:52 AM |
Decent sized drums actually have some advantages over discs on the rear.
