Toprivetguns
posted on 17/11/11 at 08:26 PM |
Banjo fitting to Sierra rear calipers
Evening gents,
Im currently running sierra rear calipers on my MK Indy. To allow clearance for my brake lines ive purchased two banjo fittings which Ive
fabricated to fit my goodrich lines.
My problem is when I install the banjo fitting to the caliper (M10 fitting) it tends to leak. (picture below)
Now ive tried coppers rings to seal between the mating faces, however with no luck they still leak.
What would anyone recommend? Nylon washer seals?
Regards
Only drive as fast as your angel can fly... !
russbost
posted on 17/11/11 at 08:41 PM |
IIRC the Sierra caliper doesn't have a machined face, only cast, it was obviously originally intended to seal with the standard male union in
the bottom of the drilling.
To seal a banjo, even with a copper washer you must have a perfect face to seal against, if you're very good with a file, you just might acheive
a good enough finish, but really you should take the calipers & get them machined. The alternative if you have room is to use a straight swivel
connector with a suitable bend in it.
Toprivetguns
posted on 17/11/11 at 08:49 PM |
Russbost,
Thanks very much for your reply. Do you an example of a straight swivel connector?
russbost
posted on 17/11/11 at 09:03 PM |
If you look at the picture in my ebay ad
Motorcycle brake lines brake line kits Stainless Braid | eBay
the top row far left is an ordinary straight male swivel, the 5th in from the left (dark red colour) is a female with a 90 degree bend, the same
extended necks can be used with the male swivels, bent anything up to 90 degrees, sorry haven't got a convenient pic of a swivel male with a
bend, but hope you get the idea.
matt_gsxr
posted on 17/11/11 at 10:38 PM |
As Russ says, although I didn't find it that difficult to sort it out with a bit of gentle filing and I am not particularly good at this
stuff.
The other thing to be aware of is the bottoming out of the banjo, as the hole isn't very deep.
I think the banjo mod on Sierra callipers is quite popular as it can help with 13inch wheels.
Matt
bob
posted on 17/11/11 at 11:19 PM |
I cleaned the face up on the sierra calipers with a fine wet n dry, fitted the banjos with some copper rings from GM Vauxhaul part (thicker than the
ones i had with the banjo's supplied and stopped the thread bottoming out).
Snuggs
posted on 18/11/11 at 09:20 AM |
I failed SVA on this point but that was 7 years ago.
The tester wanted to see that the surface was flat/machined.
If you have not yet passed IVA I would suggest that you take photographs.
