Trollyjack
posted on 19/11/11 at 09:58 PM |
what is allowed
Hi
currentley building a engine for the locost series
what is allowed on the valve timing
read through the regs it says that offset dowels are allowed
but is vernier sprokets or duel sprokets allowed
TrollyJack
locost47
posted on 19/11/11 at 11:01 PM |
locost eng
offset dowel yes to get perfect timing but no vernier allowed ![](/images//smilies/smile.gif)
Trollyjack
posted on 20/11/11 at 07:08 PM |
thanks
TrollyJack
DixieTheKid
posted on 20/11/11 at 07:23 PM |
Thats supid! Can you not sick a cam cover over the top would they remove it and check?
COS IT'S Worth IT
TimC
posted on 20/11/11 at 07:37 PM |
quote: Originally posted by DixieTheKid
Thats supid!
Why stupid? Its about a level playing field and about trying to minimise the amount of expensive parts involved.
Err, yes - they'll strip the head if need be.
[Edited on 20/11/11 by TimC]
steveiow
posted on 20/11/11 at 07:40 PM |
Lol, yes. They would check.
Regs are there to be observed not blatantly ignored.
Who would want to win knowing they had done it illegally?
The essence of the Locost series is that it is pretty much down to driver skill, and certainly not budget, and people operating outside the regs soon
find the paddock a rather lonely place to be.
2012 Locost Race Car #12 - for everything Locost Racing: www.SEWC.co.uk
DixieTheKid
posted on 20/11/11 at 07:42 PM |
bloody hell!
COS IT'S Worth IT
locost47
posted on 20/11/11 at 07:48 PM |
locost eng
scruttineers will & have removed heads /cam shafts & will find the cheats out & in many classes they have ![](/images//smilies/bigsmile.gif)
DixieTheKid
posted on 20/11/11 at 07:53 PM |
Im not saying cheat, what im saying is that its supid that you can use off-set dowels as apposed to varniers.
COS IT'S Worth IT
procomp
Hi
There is only 2 real choices with the valve timing. Your either going for bottom/mid range grunt or a higher revving top end setup. Use a decent
manifold to suit the chosen setup and your sorted once you have the correct jetting to suit. The only thing to note is that due to Kent cams having a
"tolerance" in their machining you cant take it for granted that there recommended figures are correct. Take multiple readings on all 4
cylinders.
As mentioned the Locost championship is one off the closest matched formulas in the UK. And as proved again this year those who take the wee with the
regulations are caught. And again for 2012 the regulations are being further tightened to ensure equal performance.
Cheers Matt
alistairolsen
posted on 21/11/11 at 04:07 PM |
Seems daft, as the rolling road time is the largest expense, so if I was of a mind, Id be fitting a vernier, running it on the rollers to find the
ideal timing, then getting the correct offset dowel to replicate that timing without the vernier. Thus the allowance of timing adjustment means Ive
either purchased two parts, or wasted rolling road time swapping dowels in and out.
I'm all for the championship but that one doesnt make sense to me!
My Build Thread
D Beddows
posted on 21/11/11 at 04:36 PM |
Well yes that's obviously what people do A lot of the rules were devised with 'low cost' in mind - most of the really silly ones
(like not being allowed to use a 2000E gearbox BUT you could spend 4 times the price of a 2000E box getting a Type 9 with the same 'standard
Ford' ratios built up) have gone but there's still a couple that don't appear to make much sense. Rules is rules though and over the
years there have been numerous........ how shall we put it.......... cheating b*stards.......... so they are there and enforced for very good reasons
Neville Jones
posted on 21/11/11 at 05:06 PM |
I take it that a knock sensor in the electronic ignition box is a no no. ![](/images//smilies/bigsmile.gif)
D Beddows
posted on 22/11/11 at 04:22 PM |
No, as I recall several people used to hide that sort of thing in their 'datalogging' boxes instead........
Neville Jones
posted on 22/11/11 at 05:52 PM |
On the subject of being acceptable, to digress a little, I had an interesting conversation with Keith Messer regarding alternative front lower ball
joints. Procomp Matt was stood by as well, listening intently.
Keith's reply to what I was proposing, was that 'it should be able to be made by a carpenter on his keitchen table, with normal workshop
tools.' He implied I was a professional, which I am, but i don't earn my living just building cars. So I'm not a professional car
builder.
Depending on how good a carpenter a man is, and what you define as 'normal workshop tools', the options would seem, for a man like me, to
be fairly wide spread.
Nev.
D Beddows
posted on 22/11/11 at 06:34 PM |
Wood.......... so that's where I was going wrong all those years......... ![](/images//smilies/bigsmile.gif)
