jambojeef
posted on 15/12/11 at 09:29 AM |
FS: LPG Kit for sale, ECU, all hardware, spare wheel tank, download cable and adaptors!
Hi All,
Anyone for cheap motoring?!
I had this on my 528i BMW for about 3 years and it was excellent, toured europe and ran on LPG everywhere - much cheaper overall and got to cruise
about in a car I liked whilst paying much less for fuel and its pretty straightforward to fit.
STAG300 6 System - 6 cyl sequential LPG injection - no noticeable difference from petrol when driving
VSGi vapouriser - good for around 200bhp
Donut tank means it sits in the spare wheel well
Auto switchover from petrol to LPG and back - one little switch and gauge on dash
Full instructions with the kit
New injector block and filters in the last couple of months
Auto tune facility with the software means you can auto calibrate and drive off straight away - you can further tune with a laptop and the download
cable (included) if you want to
Ready to fit - you'll need some new hoses but everything else is there ready to go.
£250 for everything - can deliver anywhere along the A1 between Newcastle and Bedford on Monday next week
jossey
posted on 15/12/11 at 09:33 AM |
what sort of cost per mile was you getting.
would it be better than a 525d version of the bimmer? that gets about 40mpg average.
David Johnson
jambojeef
posted on 15/12/11 at 10:00 AM |
Yep it would better than a 525d.
I think the general concensus is, you lose about 10% of your petrol efficiency but with LPG being 50% the cost of petrol and diesel it works out
pretty favourably.
I thought it was a useful saving when I used to drive the BMW.
Geoff
PSpirine
posted on 15/12/11 at 10:31 AM |
I think I'd like this...
Can it do 4cyl?
ali f27
posted on 15/12/11 at 10:35 AM |
Hi going to find out if it will go on my mg zt mybe you know cheers ali
posted on 15/12/11 at 11:10 AM |
Stag is a good system.
Savings on LPG depend very much on local forecourt price and how far you live from the pump.
K & KV6 engines work well on LPG no long term problems.
Stuart_B
posted on 15/12/11 at 06:27 PM |
hmm, do i buy the lpg kit then the 328 msport bmw i want to after?? lol
where about's are you?
stu
jambojeef
posted on 15/12/11 at 07:24 PM |
Haha! Of course!
I'm in Newcastle but am travelling down south for Xmas on Monday and can the kit with me to Bedfordshire if that helps?
Geoff
Stuart_B
posted on 15/12/11 at 07:42 PM |
still miles away
but if you still have it in the new year, let me know
stu
Nick Jones
posted on 17/12/11 at 03:54 PM |
Strongly considering LPG as an addition to my Triumph 2.5PI. This is already running Megasquirt management, so adding LPG injection is not as daft as
it first sounds. In theory it's even possible to do without the second ECU.
Pity we are in opposite corners of the country (I'm in Somerset) - don't imagine the carriers will be all that keen of transporting the
tank?
Regards
Nick
posted on 17/12/11 at 07:03 PM |
Will it fit a RV8??
jambojeef
posted on 19/12/11 at 02:55 PM |
Ah Cooz!
Well some of the kit will - i.e tank, sender, vapouriser, solenoids etc but you'll need to swap the ecu over for a motogas 8 and sell this
motogas 6 to someone with a 6cyl motor.
If you fancy a look-see, U2U - its in the garage
Geoff
jambojeef
posted on 21/2/12 at 09:48 PM |
Bump!
Any takers before the bay, give me a shout
Geoff
WestfieldSEI
posted on 22/2/12 at 08:49 AM |
Always wondered about this, interested, but how do the gas injectors mount into the inlet manifold? Is it a tough job to do?
posted on 22/2/12 at 11:54 AM |
The gas goes manifold through simple screw in spud connectors ---- on must kits it is simple M6 hole that is drilled and tapped for the
connector close to the petrol injector. Injectors themselves (usually a block or 3 or 4 depending on number of cylinders) are connected
by flexible tubing to the manifold "spuds". If you google for "Tinley Tech" you will find good info. My
conversion took me about 20 working hours and a lot more thinking doing the same type of car again would take me about 10 hours. I used a a
cylindrical tank but a using a doughnut shaped tank is a lot quicker and easier.
There are pictures of my DIY LPG conversion on the Rover in my photo archive but they don't show thr injector valve block or manifold
spuds because they are not visible below the manifold.
This is an LPG Injector for a 4 cylinder
Link to Stag LPG Manual
[Edited on 22/2/12 by britishtrident]
WestfieldSEI
posted on 23/2/12 at 07:16 AM |
Thanks for that and apologies for interupting the thread....
jambojeef
posted on 23/2/12 at 09:29 AM |
No problem
Kit is sold pending payment.
Thanks all for your interest.
Geoff
