r3nuf
posted on 15/8/04 at 05:37 PM |
Poly-Bushes Insertion Technique!
Has any one got any advice on how to make it easier to insert the Poly-Bushes into my wishbones etc.
Done a couple, but didn't seem as easy as it could / should be?!
How much grease should i pack in them and where?
Gary
subk2002
posted on 15/8/04 at 05:58 PM |
Everywhere and loads
put them in the vice
Drew
mangogrooveworkshop
posted on 15/8/04 at 06:19 PM |
Someone posted the type of grease a while back .......search please
Mark Allanson
posted on 15/8/04 at 06:20 PM |
Here we go again, tin hats on again lads!!
posted on 15/8/04 at 06:23 PM |
by general concensus, i believe it wants to be a moly-disulphide grease. put the grease where you want, it wont be the end of the world if you get it
wrong, whatever other WW3 threads might make out. dont grease the inside of the crush tube though, or the bolt.
ps i used a persuader to get them into the wishbone tubes.
[Edited on 15/8/04 by JoelP]
r3nuf
posted on 15/8/04 at 06:39 PM |
Ta.
Was so intent on getting the rubber mallet to wack them in that i forgot about the vice sat on my workbench! Will give that a go.
posted on 15/8/04 at 07:00 PM |
if you arent using seamless, it will be easier to file the seam down a bit.
Hugh Jarce
posted on 16/8/04 at 06:02 AM |
The seam in ERW is an added bonus it helps lock the bush in case you do get grease between the wishbone and bush.
The pay isn't very good , but the work's hard.
DaveFJ
posted on 16/8/04 at 08:06 AM |
This has been covered so many times it may be worth searching the archives......
For my tuppeny worth - put the bushes in the freezer for a couple of hours - works wonders!
Dave
