steve m
| posted on 6/1/12 at 05:51 PM |
Castle nuts on the bottom wishbone
I still have the castle nuts and split pins on my lower front wishbones , and the look quite tatty
Can i change them to normal lock nuts? as everthing else on the suspension is nylocked
If so whats the thread size on a maxi lower ball joint ?
wicket
| posted on 6/1/12 at 06:03 PM |
I've used Nylocs on all of my suspension fasteners with no problems.
| posted on 6/1/12 at 08:41 PM |
It may depend on the manufacturer! Wouldn't be the first time I've come across different threads on what is supposedly the same part. The
best way would be to remove the nut and measure the thread
craig1410
| posted on 6/1/12 at 09:18 PM |
I'd have said nyloc was fine...until I saw this video!
http://www.google.co.uk/url?sa=t&source=web&cd=3&ved=0CCsQtwIwAg&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DmgwmuZuJ02I&ei=sWM
HT4DaD4z14QTuz72NCA&usg=AFQjCNEPSZDEnrN8BW3ouI3bv_1Zw7yCcg
Given that the bottom joint is being pulled apart constantly by the corner weight I think a castle nut isn't a bad idea. Can't you just
clean up the existing nut and fit a new pin?
