jon200
| posted on 12/1/12 at 04:44 PM |
tyre pressures
what tyre pressures should I be running on a 195/50 15" rim? Its for a Locost with a zetec lump and a fatty driving. There was only 20 all round
so I put it youp to 25 but thought therws not much weight so maybe it should be softer. I can't do a search from my touchpad but I'm sure
its been covered a gazillion times before.
cheers Jon
ReMan
| posted on 12/1/12 at 05:42 PM |
20 would be closer imho
Why did you put it up?
www.plusnine.co.uk
jon200
| posted on 12/1/12 at 06:03 PM |
I didn't know what it should be, just thought it was a little low. Is there an online calculator anywhere to work it out by corner weights?
lewis
| posted on 12/1/12 at 06:18 PM |
I run 18psi all round if that helps on 14" but yours should be around that figure too.
I am a driving god!..........sort of
jon200
| posted on 12/1/12 at 06:22 PM |
is that enough to keep the tyre on the rim then,
steve m
| posted on 12/1/12 at 06:36 PM |
16psi in mine, at 18 upwards ther car feels as though the car will slide of the road
omega0684
| posted on 12/1/12 at 06:58 PM |
between 16-18 psi,
jon200
| posted on 12/1/12 at 06:59 PM |
I had better let some back out then.
what wheel size you running Steve?
jacko
| posted on 12/1/12 at 07:10 PM |
I have the same size wheels / tyres as you and a boat anchor pinto engine and i have 19psi in them
if i am going to a show on motor ways i put them up to 23 psi
jacko
ReMan
| posted on 12/1/12 at 07:13 PM |
http://www.locostbuilders.co.uk/forum/52/viewthread.php?tid=157598
Might help
www.plusnine.co.uk
jon200
| posted on 12/1/12 at 07:25 PM |
thanks ReMan that's some good info, I will put thm back to 18-19psi all round and try it.
steve m
| posted on 13/1/12 at 12:06 PM |
Im running 205/55/13" tyres all front and back
TrophyJem
| posted on 13/1/12 at 01:08 PM |
I have the same size tyres as you and run 18psi all round
whitestu
| posted on 13/1/12 at 01:13 PM |
25 is way too high. I played about with mine on a track day and ended up with them at 14psi cold. Grip was way better than with 18-20 psi.
My car is an Indy with a Zetec engine and had 195/50 Yoko A539s.
Stu
