RMarine
| posted on 17/1/12 at 09:56 PM |
wheel spacers
Hi Guys, does anyone know what the maximum wheel spacing you are allowed (wheel spacers)?
Its all Mark Evans fault......
daniel mason
| posted on 17/1/12 at 10:08 PM |
not sure on maximum but you can buy decent sized hubcentric ones. what application are you wanting them for?
loggyboy
| posted on 17/1/12 at 10:13 PM |
Check out the monsters that they use on the fake ferraris:
(bottom right)
http://www.extreme-sportscars.com/360/gallery.html
RMarine
| posted on 17/1/12 at 10:19 PM |
i have balls up again(i think). i got a set of wheels from a westy, fitted them and the tyre's are rubbing (at the back) so i fitted 2 sets of
30mm spacers 60mm to each side and its still not prefect. tonight i decided to fit my wing stays and fell foul again....... i think i need to add
about 60 mm to the front as well. so i am now thinking of selling my wheels and buying new wheels..... but that cost MONEY
So i was thinking of wheel spacers unless someone can advice me if a little man in a white coat will say "thats not allowed" at the iva
center....
daniel mason
| posted on 17/1/12 at 10:24 PM |
that cant possibly be right. what widths are te wheels you have and what offset? also what size rims are they?
RMarine
| posted on 17/1/12 at 10:28 PM |
i am not sure, i will go to the garage tomorrow and get back to you.
daniel mason
| posted on 17/1/12 at 10:34 PM |
also take some photos and post them so we can help a bit more. cheers
thefreak
| posted on 17/1/12 at 11:04 PM |
I think the thickest I've made and sold which were bolt on were 75mm. They're a fair old chunk of ally, and it makes you wonder if
it's not cheaper to sell the alloys and buy the right ones when you're spending £170.00 on a set of 4 spacers
snapper
| posted on 18/1/12 at 07:22 AM |
Sound like you've bought wheels that are to wide and have to much offset (very large back space)
Sounds like they are Sierra offset (ET38) and are fitting to a live axle car that has a required offset of (0 to +6) Escort
If the offset is large and the rim wider than your car is designed for you could be adding a lot of backspace.
Plenty of people want Sierra offset so sell on and use money to buy the correct wheels.
Expensive spacers, 16 longer wheel studs, extra wheel bearing load.
You've bought the wheels and feel you must fit them come what may.
There wrong cut your losses and moove on.
I eat to survive
I drink to forget
