Author: Subject: Type 9 jumps out of 4th question
Dopdog
posted on 21/1/12 at 08:14 PM Reply With Quote
does anyone know why my gearbox kept jumping out of 4th. if i accelerated then let off the power it would jump into neutral. it would also jump out of gear on the way down from 5th.
any suggestions?
AdrianH
posted on 21/1/12 at 08:26 PM Reply With Quote
Both situation sound as though wheels driving engine so possibly movement in engine and box and the gear stick being pushed out by the metalwork around the top of the tunnel.
If just started to happen look for a week engine or type 9 gearbox mount allowing more movement. Can you make it do it in second?
It the grub screw fully in at the side of the gearbox that is on the detent?
Adrian
also what oil have you put in, have you recently changed.
[Edited on 21-1-12 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
Dopdog
posted on 21/1/12 at 08:29 PM Reply With Quote
HI Thanks for the reply its a brand new just serviced box from tran x with the correct oil in, the same box did come out of the car when it needed to be serviced with no issues?
Dopdog
posted on 21/1/12 at 08:31 PM Reply With Quote
it does not do it in second, also it just takes the slightest touch on the stick and it come out of 4th?
[Edited on 21/1/12 by Dopdog]
AdrianH
posted on 21/1/12 at 08:40 PM Reply With Quote
I would check the detent screw then is tight and not working loose as it did on mine after rework.
Adrian
Dopdog
posted on 21/1/12 at 09:14 PM Reply With Quote
what is the detent screw and where is it located? sorry to ask but have not heard of this.
AdrianH
posted on 21/1/12 at 09:20 PM Reply With Quote
To give it it's correct name in the book it is the selector locking pin and spring.
Here is a pic from book
pinandspring
pinandspring
It is on the passenger side of the box just behind the bell housing near the top.
Reason I suggest this is that I had just had my box done and within not many miles it would jump out of gear on oiver run, mine was first (modified gearset).
Took the box out to later find the screw holding the pin and spring in was loose and just proud of the casing. Gear changes was very easy with little effort needed to move it.
With an Allen key I tightened the grub screw in until it locked, this provided more tension on the spring and more effort to remove from gear.
Just a thought of what I found.
Adrian
