sprouts-car
posted on 21/3/12 at 08:52 PM |
Is it dead
Evening all,
My desktop PC has stopped working.
The symptoms are:
As soon at it has power the fans start going (all three, psu. cpu and case)
The usb based lights (ie mouse laser and keyboard indicator) lights flash once.
Nothing else happens. monitor never leaves standby.
the cd drive wont open
the power and reset buttons don't do anything even if held for 10 seconds.
the only thing i can then do it turn is off on the psu.
So what do you think the problem is?
PSU not giving power to the motherboard?
CPU totally dead?
what else can I try?
Really dont need to be spending lots on a new pc right now
mb is foxconn 945p7aa if that help anyone?
Build blog
mookaloid
posted on 21/3/12 at 09:05 PM |
unplug all your USB items except KB and Mouse and try it. Sometimes the USB power draw is too much to get it to fire up.
If that does it then upgrade your psu
If that doesn't do it then I would still suspect the PSU - they don't cost much so worth a try.
D Beddows
posted on 21/3/12 at 09:13 PM |
That's happened to me - in my case the motherboard had failed somewhere to do with the graphics card and it refused to do anything apart from
turn the fans on and flash a few led's until I fixed it. If you have a graphics card as opposed to integrated graphics it might be worth trying
a known good one. If it is the card they're hardly expensive (unless you're a gaming type obviously)
[Edited on 21/3/12 by D Beddows]
vanepico
posted on 21/3/12 at 09:18 PM |
hmm I wouldn't have thought the psu would have much to do with it. If the fans come on, disconnecting the mouse and keyboard, which are very low
current devices, would make little to no difference. If it worked before I doubt it would all of a sudden stop being able to supply the required
current.
What I would recommend is earth yourself to a radiator or something then reseat all the plugs between the PSU and motherboard and drives.
Did it make any noticable bang or magic smoke escape from anywhere?
I would guess, from what you said, the processor/motherboard might be done for.
sprouts-car
posted on 21/3/12 at 09:19 PM |
I unplugged the mouse and keyboard which were the only two usb things anyway. I also unplugged the fans to further reduced power demand. No change.
quote: Originally posted by D Beddows
That's happened to me - in my case the motherboard had failed somewhere to do with the graphics card. If you have a graphics card as opposed to
integrated graphics it might be worth trying a known good one. If it is the card they're hardly expensive (unless you're a gaming type
obviously)
That would explain the lack of picture but what about other thinks not working, ie power buttons and cd drive.
Unless the mb just gives up at some point. I'll see if I can borrow another one.
Thanks for the suggestions guys.
Build blog
vanepico
posted on 21/3/12 at 09:21 PM |
Also I'm pretty sure CD drives should open even if they are not connected via IDE to the motherboard, just powered up.
sprouts-car
posted on 21/3/12 at 09:25 PM |
current.
No bang or magic smoke. I did turn it off at the wall last night which I don't normally do (after a proper shutdown of course).
The system has been unchanged from new (about 5 years ago now) except that I put more ram in about 3months ago, but that went well and its been fine
since, could that have done it?
I'll give the reseating connectors a go as i don't think i have anything else to loose at this point.
Build blog
sprouts-car
posted on 21/3/12 at 09:28 PM |
If I disconnect the IDE then it will open and close. But with that connected I cant.
Very odd
Build blog
vanepico
posted on 21/3/12 at 09:33 PM |
Ah, that probably means that the motherboard is reading from it, or attempting to read from it, as if it were trying to boot from a disc. What kind of
connector is being used to connect the screen? If it is DVI or HDMI try using VGA. I think the fact that the cd drive will only open when it is
disconnected means the motherboard is partially working.
sprouts-car
posted on 21/3/12 at 09:35 PM |
Its vga.
The other difference, was that until yesterday i had a dvd in there!!!
I need to find that dvd a put it back in!!
watch this space.............
Build blog
sprouts-car
posted on 21/3/12 at 09:39 PM |
quote: Originally posted by sprouts-car
Its vga.
no
Build blog
vanepico
posted on 21/3/12 at 09:46 PM |
Is the graphics card an external one? I.e is the card with the VGA mounted into one of the PCI slots? If so try reseating it.
sprouts-car
posted on 21/3/12 at 10:10 PM |
yes its external. I removed it and tried starting. Still the same issues with the cd drive and the power buttons.
Re inserted and all same.
I think it must be the mb or processor now
Build blog
pmc_3
posted on 21/3/12 at 10:13 PM |
Try reseating the RAM or taking out the modules in turn. You wont even get a post screen display if there is a problem with one of the modules.
sprouts-car
posted on 21/3/12 at 11:43 PM |
same result with every combination of ram.
thanks for your help every one.
Build blog
vanepico
posted on 21/3/12 at 11:48 PM |
As a last ditch attempt you could always try reseating the processor, by the sounds of it you got nothing to lose.
Could always take it into a professional computer shop, they may have diagnostic equipment or something.
Jasongray5
posted on 22/3/12 at 12:33 AM |
Have you tried giving it a good solid slap on the side? Shouting and swearing may also help.
Jason
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
RickRick
posted on 22/3/12 at 07:01 AM |
what about the bios battery, or atleast the bios settings, maybe worth trying a new battery, and then resetting the bios settings, but you'll
need to know what settings to put back in
Macbeast
posted on 22/3/12 at 07:13 AM |
If he has a blank screen, won't it be difficult to mess about with the BIOS ?
D Beddows
posted on 22/3/12 at 09:19 AM |
If you're happy with the current capabilities of your computer a 2nd hand motherboard of the same spec from ebay is only going to cost you
£30ish quid. Odds are it's just the motherboard so swap everything over (which really isn't rocket science) and you're up and
running again
