loggyboy
| posted on 21/3/12 at 09:11 PM |
Stub axle info (drum and disk)
How do disk stubs interface with bearings?
I have just got some Disk shafts in the hope I can move over to Lobros but retain my drums, I dont want the hybrid route, I want both inner and outer
lobros.
The drum brake stub shafts have a about 50mm smooth area which then turns to splines. The smooth area sits within the bearings. however the disk stubs
have a splined finish accross their whole length, so where does the bearing sit?
Pics would be great if anyone has any.
minitici
| posted on 22/3/12 at 08:09 AM |
The bearings run on the stub of the drive hub which slides onto the splines of the stub axle.
  sierra/westfield drive flanges
[Edited on 22/3/12 by minitici]
loggyboy
| posted on 22/3/12 at 09:19 AM |
Ahh perfect, (well not perfect for me, but the explanation is!)
So i need disk hubs, but how on earth will they mate to the drums? Im sure someone said they had done this using lobro outers...!?
| posted on 22/3/12 at 01:28 PM |
I have a Cosworth back end on mine with 10" drums from a xr4 thing.
I simply cut the caliper carrier lugs off the bearing housing and bolted them over the drums back plate just as you would do with a normal drum setup.
loggyboy
| posted on 22/3/12 at 04:40 PM |
I think the issue with my setup is down to the fact my drums seem to have a differnt drive hub to others. I assume you used a disk hub and simply
bolted your drums to the the hub?
