scoop
| posted on 5/4/12 at 09:11 AM |
Steering knock with sierra column
As above really and it comes with a sticking point when in the central position.
I'm pretty sure it's in the column and not any of the other joints. It oes have a modified boss o fit a lotus wheel.
Any ideas?
loggyboy
| posted on 5/4/12 at 09:17 AM |
have you ruled out an issue with the rack?
scoop
| posted on 5/4/12 at 09:34 AM |
Well I'm going purely on feel at the moment and I've convinced myself it's the column. I will disconnect the two over the weekend
and see it still does it. I wont be happy if it's the rack as it was new, not recon etc.
Any suggestions on alternative columns. Preferably adjustable?
loggyboy
| posted on 5/4/12 at 10:09 AM |
Have you checked that nothing is catching on the column or joints?
scoop
| posted on 5/4/12 at 04:03 PM |
I have. It's just started so I've looked to see if anything has moved or come loose.
Macbeast
| posted on 5/4/12 at 04:18 PM |
Indicator cam ?
scoop
| posted on 5/4/12 at 04:54 PM |
I'm not sure if it's still in there but I will check. Didn't think of that one. Ta
