Mave
| posted on 1/9/04 at 03:25 PM |
OZ F1 wheels
I've seen some second hand OZ F1 wheels (15" advertized, and was wondering if anyone had a picture of a Seven with those wheels, just to
see what it looks like.
Another question: these come from a Golf 3 (PCD 4x100), but are multifit, so perhaps also 4x108. Will that be all about fitting to the Ford-stuff? I
believe the ET for these wheels where in the region of 35, so that's correct, but what about the center ring?
I'm still not sure if I should be sensible, and go for 15", or go for bling-bling 17"...
tigertom
| posted on 1/9/04 at 03:31 PM |
go for 17"ers and be different.
ned
| posted on 1/9/04 at 03:40 PM |
the fitment should be ok for the ford studs and the offset should be suitable as it's the same as all the MK indy boys use..
Ned.
beware, I've got yellow skin
Mave
| posted on 1/9/04 at 04:42 PM |
Well, I'm not sure if OZ combines the 4x100 fitment with 4x108.
richardR1
| posted on 1/9/04 at 05:36 PM |
Golf centre bore is 57.1mm whereas Ford is 63.3mm so you will need to obtain a new set of spigot rings but being OZ these will be readily available at
alloy wheel stores. If you have access to the wheels then just measure the PCD - distance from the centre of the stud hole to the centre of the stud
hole opposite. The only other fitment it is likely to be is 114.3mm that fits a lot of mid size Jap stuff e.g Primera etc. However it is most likely
to be 108mm Ford
phelpsa
| posted on 4/9/04 at 04:07 PM |
or 4x98, fiats and lancias. I have seen a few wheels with those fitements.
Adam
Trev Borg
| posted on 4/9/04 at 09:28 PM |
I have the 16" ones on my ibiza gti. When i tried to get a replacement for one which got a wee bit bent i was told that they no longer did the
exact same wheel.
Cos they have two different fitments, i could still get one to fit the seat/vw but the other fitment on the wheel would be different from the rest.
SO depending on the age of the rim they could be VW/ford or VW/vauxhall. (i don't know if it is ford and vauxhall was just an example)
Oh and they are indeed a pretty wheel, but easily damaged.
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
Trev Borg
| posted on 8/9/04 at 09:18 PM |
just checked.
mine are 100mm and 108mm
