alfasudsprint
| posted on 1/9/04 at 08:47 PM |
steering column
I need to make up a length of steering column to fit between two universal joints...how do i get the longitudinal splines onto the ends of the solid
rod where it mates with the UJ's? Presumably machined on, but how? Is a very specialist or a normal metalworkers job?
mangogrooveworkshop
| posted on 1/9/04 at 09:42 PM |
use the ones that come in your socket set. You only need square ends.
Put a sleeve on the other end or get two and make em into one . Weld that onto shaft.
violentblue
| posted on 1/9/04 at 10:10 PM |
that will work, but it won't last.
a few pics of my other projects
