Author: Subject: Rear drum bleeds very slowly
theduck
posted on 26/5/12 at 07:18 AM Reply With Quote
I've fixed all my break lines now but one of my rear drums bleeds very slowly, after 10minutes there is fluid in the bleed line but not reached the jar! Any thoughts as to what I am looking for to fix it?
snapper
posted on 26/5/12 at 08:04 AM Reply With Quote
Loosen pipe at the cylinder if it flow at a better rate before the cylinder ( from the pipe) it's the cylinder, if not, remove pipe at the other end, T joint?
It's more than likely the cylinder but could also be a blocked pipe
I eat to survive
I drink to forget
owelly
posted on 26/5/12 at 09:01 AM Reply With Quote
Blocked bleed nipple? Remove the nipple and bleed the cylinder with your finger over the hole. Wear gloves, goggles, face mask, chemical suit, helmet, tin hat, EMP suit, gimp mask, etc., if you think you'll get a face full of brake fluid.
http://www.ppcmag.co.uk
posted on 26/5/12 at 10:08 AM Reply With Quote
If everything is new likely you have a fitting block by swarf.
If you have braided flex hoses then it is more than possible that one of the end fittings on the hose is not drilled through completely.
theduck
posted on 26/5/12 at 07:37 PM Reply With Quote
Cheers guys will try your suggestions.
theduck
posted on 27/5/12 at 11:03 AM Reply With Quote
Thanks all for the help. Turned out to be badly twisted flexi.
greavesy7
posted on 28/5/12 at 05:27 AM Reply With Quote
glad to see you are sorted now
