pauladamss
posted on 24/6/12 at 11:45 AM |
Oil sandwich plate
Im trying to fit some gauges to my gsxr engine oil pressure and temp however the way suggested is to use an oil sandwich plate this however is proving
to be near on impossible. Does anyone know where i can get one with a 20x1.0 thread lots of 20x1.5 about not 1.0 or is there another way of doing it.
Jon Ison
posted on 24/6/12 at 12:51 PM |
I take oil pressure from the main oil gallery, bottom front left when fitted in car, I take oil temp from a sensor in the sump.
pauladamss
posted on 24/6/12 at 01:22 PM |
Have you removed the original oil pressure sensor and used that hole? and have you drilled and tapped a hole in the sump?
Jon Ison
posted on 24/6/12 at 01:30 PM |
Yes re oil pressure, I had a aluminium spigot welded to the sump then drilled n tapped that for oil temp.
pauladamss
posted on 24/6/12 at 01:48 PM |
Did you have to retap the oil pressure?
