Author: Subject: GBS Zero front shock fixings
MikeCapon
posted on 13/7/12 at 08:32 AM Reply With Quote
Morning all. I am trying to sort some dampers for a GBS Zero and I have a question for the GBS Zero owners on here.
What is the internal width of the chassis fixing for the front damper? My man over here has measured 50mm but that seems to be an odd size and also contradicts info I've dug up elswhere.
Thanks in advance.
Mike
www.shock-factory.co.uk
femster87
posted on 13/7/12 at 09:06 AM Reply With Quote
If you dont have before then i would measure up tonight. But I think 50mm would be quite close. As I had to used a spacer on mine
