Author: Subject: need help identifying these bits
richardh
posted on 15/7/12 at 04:14 PM Reply With Quote
Hi, RV8 manifold with 38DGAS but i cant identify what these connect to or if i blank them off
bit on manifold and black bit at base of weber
[Edited on 15/7/12 by richardh]
Time for a change!
jacko
posted on 15/7/12 at 05:45 PM Reply With Quote
The black pipe at the base is a vacuum pipe think its for a dizzy vacuum
richardh
posted on 15/7/12 at 05:53 PM Reply With Quote
oops, my dizzy one is the smaller brownish one at the left and goes from dizzy to manifold on far side
i've got my flow/return pipework on ok, fuel in, brather from manifold to brake servo
the silver bit on manifold i'm thinking is another tap for a water supply to something else ???
black one might be for an additional breather pipe ?
Time for a change!
mookaloid
posted on 15/7/12 at 06:42 PM Reply With Quote
Black bit looks like crank case breather connection to me.
silver one on manifold looks like water cooling to me
deltron63
posted on 15/7/12 at 08:30 PM Reply With Quote
The breather on your rocker covers go to the black one. The silver one should be for the water temp sender, but it looks like it's been converted to a water outlet pipe
richardh
posted on 16/7/12 at 06:55 AM Reply With Quote
Thanks folks
Time for a change!
jacko
posted on 16/7/12 at 08:05 PM Reply With Quote
Sorry i got it wrong i was trying to remember when i had a ford v6
Jacko
